aluminum Inlets and pcv system
01-06-2017, 11:48 AM | #1 |
132
Rep 573
Can people post their setups for either VRSF, tft or mmp setups?
I went ahead with an inlet and dp install 6 months ago. Car has 60k miles i always thought the pcv setup was poorly done and i'm curious to see other peoples setups. My problem is car will occasionally smoke going to a complete stop from a pull. i did notice my rear turbo was leaking during install so i'm not sure if they're going bad or if the system is pressuarizing. my next step is to do a rob check valve upgrade and someone upgrade the line from the intake My setup is vrsf inlets 1'' rubber line from intake to 90*brass setup to stock check valve. i'll snap a pic of my setup as soon as i can |
