335i rattleing, New turbos.
01-05-2017, 12:15 PM | #1 |
38
Rep 204
hello Guys. I bought new turbos, cause I had wastegste rattle. My mechanics replaced turbos. everything is ok, but my N54 is still rattleing. what is the problem? help me, please. Maybe that my car is tuned? Do You have any ideas?
01-05-2017, 01:22 PM | #3 |
530
Rep 2,083
Are you running JB4? If so, you need to play with the wastegate settings.
My new turbos rattled with JB4 even after spending hours playing with the settings. Switched to MHD and the rattle is mostly gone.
2013 135is DCT Carbon Black Metallic |
01-05-2017, 02:45 PM | #5 |
48
Rep 146
Check all vacuüm hoses and boost solenoids for leaks and proper functionalty. If all is good you could get the mhd app and flash stock with rattle fix slider option
01-05-2017, 02:51 PM | #6 | |
421
Rep 1,643
Next, make sure wg are adjusted correctly. Finally, look for a software fix.
2007 E92 335i MT
01-05-2017, 03:13 PM | #7 |
38
Rep 204
Thanks for helping me.
I'm sure, that one plastic tube is little broken. Could It be the reason? Could U tell me, how to adjust wg? By computer, or sine mechanics things? I have to finish my wg problem, cause I spent a lot of € and there is no better. |
01-05-2017, 03:15 PM | #8 |
196
Rep 458
Start with this.
01-05-2017, 06:20 PM | #9 |
330
Rep 984
Which turbos are the new ones? Mitsubishi OEM brand new? If so, it should be the improved design which has the upgraded 8mm wastegate arm to eliminate rattling for a long time. The brand new ones wastegates do not need to be adjusted and are already pre-adjusted.
01-05-2017, 06:36 PM | #10 |
38
Rep 204
I have brand new wastegates.
Little broken on tube Could be cause of my rattle? I think about vacuum lines, but I can't see any leaks. Is there some way to check vacuum lines? I can't see more ways of my problems. |
01-05-2017, 09:38 PM | #11 |
421
Rep 1,643
How many miles old are your vacuum lines? If more than 50k just replace them all to be sure.
2007 E92 335i MT
01-06-2017, 04:29 AM | #13 |
330
Rep 984
You can go to any good mechanic who has a vacuum gun or a smoke tester to test your whole system for boost or vacuum leaks. Like I said, what brand new turbos did you get for yours? If you tell me its brand new Mitsubishi OEM ones which has the improved wastegate arm, then that eliminates the possibility of the wastegate rattling because of the wastegate itself
01-06-2017, 08:58 AM | #15 | |
Guest
Rep n/a
Drives:
OP: change ALL vacuum lines at this point (except for the hard lines; unless they're broken, of course). Also, as mentioned, are your solenoids new as well? |
01-06-2017, 07:57 PM | #18 | |
330
Rep 984
01-06-2017, 08:00 PM | #19 | |
330
Rep 984
Replace vacuum lines, tighten all your boost clamps especially around the hotside of your intercooler and lower end of the chargepipe. Look at the vacuum canisters tips and see if they are broken. If they are, replace the vacuum canisters to Stett. |
01-06-2017, 08:21 PM | #20 |
1933
Rep 1,532
Eh, don't replace your solenoids unless you broke them IMO. I'd do vac lines as basic maintenance and tighten clamps and of course replace whatever broken piece you have first. I'm hesitant to throw parts at things because these cars will eat a lot of parts if you do that.
01-07-2017, 02:34 AM | #21 |
38
Rep 204
Ok Guys, thanks a lot for helping me. I'll replace vacuum lines, replace broken plastic tube (broken is grey connection, and leaking boost air for sure). It is possible, to rattling, when boost air is leaking? Cause there is no connection with wg. Now I don't know what I have to do with solenoids...
01-07-2017, 09:55 AM | #22 |
197
Rep 1,070
Good to get under car and check everything. I had an exhaust heat shield that was rattling on my car. 10 min with some JB Weld and it's quiet again!!
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
