01-05-2017, 09:48 AM | #1 |
57
Rep 451
Power steering failure
The power steering just died on my 2013 M5. Has anyone else had this issue? It's currently at the service center.
Low mileage (23k miles), no aggressive driving. Surprised it would fail. |
01-05-2017, 10:58 PM | #2 |
57
Rep 451
Turns out there was a bad deal in the trunk area allowing water to get in where the servitronic control unit was. They dried off the unit, no corrosion found, and replaced the seal. That fixed things.
01-10-2017, 09:09 PM | #3 |
184
Rep 788
I would request they replace the control unit - steering is safety critical and water will most probably make the circuit board corrode.
If not under warranty, I would cough up the dollar and get it done, if it fails the steering goes that heavy if almost feels locked up until you are used to the extra effort, this could cause you to loose control momentarily. |
05-09-2017, 04:01 AM | #4 | |
47
Rep 170
I ask because I noticed that one of my little plugs was leaking down into the right side under the black plastic tray one day. Luckily I found some time to open it up, to discover that there was a small pool of water... After by using water bottles to see where the leak was, I ended up sealing the offending plug. |
