VRSF Catless Dowpipe: Possible Exhaust Leak
01-02-2017, 09:06 PM | #1 |
Rep 55
Drives: 2011 N55 E90
I just installed my VRSF Catless DP on my 2011 N55 E90.
The sound and performance is awesome! I really cant say enough good things about it. Ive put about 300 miles on the install at this point and have hopefully burned any residual oil or debris I may have put from my fingers on the DP itself during the install but I noticed that if I'm stopped and idling the cabin starts to smell like exhaust fumes. Now I realize that the DP is catless and there will be smelly exhaust but Im worried that there might be a leak. Is this normal? I used the provided flange to the exhaust and tightened the C clip on the turbo and DP. I also notice the smell when I'm downshifting and breaking simultaneously. When I'm on the highway or at speed the smell isn't there at all. Thanks in advance! |
01-02-2017, 09:23 PM | #2 |
9
Rep 31
I had a leak with the supplied VRSF gasket and bolts that became very noticeable after about 1k miles. After swapping to a larger diameter bolt and the OEM gaskets I don't experience any smell in the cabin at all, hot or cold days, at a stop light or motoring down the road.
01-03-2017, 01:40 AM | #4 |
26
Rep 135
The smell is very strong after the install. If your windows are down odds are you will be able to smell it if you are stopped for a little bit. If with windows up you shouldnt smell it at all.
01-03-2017, 11:26 AM | #5 |
57
Rep 399
01-03-2017, 02:59 PM | #6 |
Rep 55
Wow great info guys, thank you all so much! Yes the windows are up and the smell is strong.
Is there a good place to buy the OEM gasket online or should i just go to BMW and pay retail? Also, what bolts should i use? Thanks again! |
01-03-2017, 04:35 PM | #7 |
9
Rep 31
I apologize but I cannot recall the bolt diameter used in replacing the included hardware. I found the largest diameter bolt that would fit the existing hole in the original cat-back flange in order to ensure it remained as centered as possible on the DP flange.
Regarding gaskets, I picked mine up from ECS. |
01-03-2017, 06:13 PM | #8 |
Rep 55
Excellent info, I'll order the gasket and do a quick write up with info for anyone else with this problem.
01-03-2017, 10:07 PM | #9 |
536
Rep 2,825
ouch, smell inside cabin is not normal. I think you do have an exhaust leak.
as for gaskets, you dont have to waste your money on OEM ones. i heard that one from a hardware store (2, 2.1 inch) gasket will work just fine cheers |
01-05-2017, 10:30 AM | #10 | |
Rep 55
You are right, i have read in several threads, people say these cheap ones from autozone work well for 2 bucks a pop. Ill give them a shot before getting the OEM replacement.
Also, here are some specs i found while searching. http://www.e90post.com/forums/showpo...4&postcount=14 Quote:
