Jb4 NLTS only works sometimes...
12-30-2016, 03:25 PM | #1 |
7
Rep 60
Hi guys I've had nlts on my previous turbo car Evo ix never had any problems. The Evo never had any bog issues powerband was strong all thru the powerband.
My experience with my 335xi has been very different. I installed the jb4 with the anti-lag relay did couple of pulls at first the nlts wasn't working. I did some troubleshooting and set the user adjustment D to 14. Nlts started working I did a couple of pulls and on the last run the rpms shot up and I got a code 2E77 nlts code. My question is would this code be normal and nlts not working sometimes? Also should I leave the user adjustment D on 14. Could you guys also explain what the user adjustment D is? Does a backend flash help with the bog I get in between shifts I feel like the bog really slows down the car? Thanks for the help... |
12-30-2016, 06:36 PM | #2 | |
Joint Chiefs of Staff
4918
Rep 115,980
FUD=14 was the old firmware setting to verify the clutch wire signal is being recieved by the JB4 (shown under FP_L), the new firmware setting for that is FUA = 51. This has nothing to do with the operation of the 2STEP/NLS itself.
12-30-2016, 06:41 PM | #3 | |
7
Rep 60
So should I set it back to zero. So why does the nlts sometimes work and other times the rpms shoot up and I get a code? I double checked everything is installed properly. Is the nlts not consistent for everyone else? |
