M4 DCT Flywheel in 335is
12-25-2016, 11:50 AM | #1 |
59
Rep 235
Its the giving season right? I encourage everyone to share information instead of keeping good info secret, this helps progress the platform. I could of very well kept this to myself and gone faster and no one would of been the wiser. Happy Holidays!
The Idea: I have been working on David Rooney's 135i DCT swap for awhile now. I am very familiar with the look of and weight of the n54 DCT flywheel. While reading about a clutch upgrade on a f80/82 I noticed a picture of the flywheel in the m3/m4 and it looked much different and much lighter. I was curious and used realoem to inspect weights of the two. The difference was huge. The m4 part rang in at 8.1kg and the stock 335is unit was a whopping 12.92kg! I verified they both used the same bolts, same bolt pattern, thread pitch, and same clutch pack. On paper everything looked great. Located a used m4 dct flywheel from a junk yard and the project was on. The Swap: When the m4 unit arrived I could immediately tell it was a much lighter unit. I verified the splines on the clutch pack were the same and test fitted it onto the crank of a n54 I happened to have in the garage. Everything looked as expected. I pulled the trans out of my 335is and removed the DCT flywheel. The side by side shot says it all. The 335is flywheel is a typical bmw dual mass flywheel and the m4 unit while still listed as a dual mass did not have any noticeable play in it or even look like it was dual mass. It could be dampened internally but I could not be certain. As you can see in the photos the weight difference huge 10.5lbs between the two. The flywheel bolted right up. I used new flywheel bolts and torqued to the m4 specifications. The two cars share the same bolts. The Results: I took before and after free revving videos at roughly the same operating temp and the difference is noticeable. https://youtu.be/2gjf0byD6zQ The car felt quicker after the upgrade, no more or less than expected. Worth the 300 dollars to me. I am hoping it will help my launches at the drag strip because I've been leaving too hard with the stock flywheel and 5k launch. I am also hoping this is easier on the rest of my driveline. |
12-25-2016, 05:56 PM | #2 | |
110
Rep 1,340
12-26-2016, 12:21 AM | #3 |
aka Mike
106
Rep 1,395
This Is very cool. Well done. You make this sound like a quick swap. Is this feasible for a regular diy guy to do in the garage on jack stands or ramps?
12-26-2016, 09:25 AM | #4 |
59
Rep 235
The m3/4 dual clutch trans clutch pack is the same as the clutch in the 335is as well as any other dct trans. I know there are several cars out there pushing 700+ with upgraded clutches from Dodson and SSP.
12-26-2016, 09:26 AM | #5 | |
110
Rep 1,340
12-26-2016, 09:27 AM | #6 |
59
Rep 235
I would advise against trying to do this without a lift and a tranny jack. I'm sure someone could do it but lots of swearing would be involved and they could injure themselves.
12-27-2016, 01:43 PM | #8 |
312
Rep 412
They're the same height where it matters. If you look at the first picture, the center section with the splines is the same exact height - that's the place where it matters. The big outside ring on the N54 flywheel is there to help smooth out engagement and help with harmonics - there is nothing that touches it.
12-27-2016, 02:36 PM | #9 | |
110
Rep 1,340
12-27-2016, 06:35 PM | #11 |
110
Rep 1,340
12-27-2016, 08:15 PM | #14 |
59
Rep 235
Julian2485110.00 |
12-27-2016, 08:16 PM | #15 | |
59
Rep 235
If you want a feel for what it sounds like ride in a m3/m4 with a DCT |
12-31-2016, 08:57 AM | #16 |
85
Rep 354
well guys, having started a list on another forum to help everyone have a lightweight flywheel on the DCT cars
i am seeing on realoem that the e92 dct N54 and the 135i N55 flywheels are the same. so this options is viable to everyone with a N54 E92 DCT and E82\88 N55 DCT. Stephen from MFactory said to have their price the same as the M/T trans flywheels - 500$ they already have a DCT flywheel sample going out to them and with 10 people pledged in they gonna make our DCT work great quoted from him on the other forum - " If we can get at least 10 people on board (i.e confirmed with a 50% deposit), we can make our SMFW's for the DCT (will be same price as our MT SMFW's). Lead time around 2-3 months."
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
12-31-2016, 01:06 PM | #17 | |
Rep 1
https://www.drive2.ru/l/7106322/ |
12-31-2016, 01:45 PM | #18 |
85
Rep 354
i dont think that single mass on the DCT would be nice as a daily driver
12-31-2016, 01:59 PM | #19 | |
59
Rep 235
12-31-2016, 08:07 PM | #20 |
581
Rep 1,421
12-31-2016, 09:32 PM | #21 | |
388
Rep 1,945
12-31-2016, 09:41 PM | #22 | |
110
Rep 611
http://www.n54tech.com/forums/showthread.php?t=44226 |
