12-22-2016, 01:04 PM | #1 |
Supreme Allied Commander
3843
Rep 54,376
Drives: F80 M3
BMW F2x HD adjustable anti roll bar end links
When you lower your F2x 2 series with coilovers, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autosport is happy to introduce these HD adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autosport end links are adjustable while on the vehicle. These end links will fit the following vehicles: F2x 2 series $159.99 pair Order here: https://hpautosport.com/product/hp-a...ybar-endlinks/ Last edited by HP Autosport; 07-02-2023 at 01:22 PM.. |
01-15-2018, 08:34 PM | #15 |
3843
Rep 54,376
Drives: F80 M3
HP Autosport, Inc. is your Santa Barbara local source for adjustable HD sway bar endlinks.
wwwhpashop.com |
01-21-2018, 10:43 PM | #16 |
3843
Rep 54,376
Drives: F80 M3
04-17-2018, 11:18 PM | #20 |
3843
Rep 54,376
Drives: F80 M3
