BMW M2 Forum > M2 vs... > M2 vs M140i Dyno
      12-21-2016, 01:18 PM   #1
Imran@Evolve
Imran@Evolve's Avatar
United Kingdom
5360
Drives: All of them
M2 vs M140i Dyno
BIMMERPOST
     Featured on BIMMERPOST.com
We had the chance to dyno a stock M140i AT here today so thought it would be interesting to compare the results against a stock M2 DCT.
Both cars were using 99 RON Fuel (93 Oct) and have around 2500 miles on the clock.
The M140i is rated by BMW at 340 BHP and 369 lb.ft torque whereas the M2 is rated at 370 BHP 343 lb.ft torque.
Most of the modern BMW turbo cars make a little bit more than BMW quote on our Dyno Dynamics dyno. The M140i surprised us!
Red Line is M2 and Green Line is M140i.
Flywheel
Wheel Power
As you can see the M140i had a higher peak torque figure just like BMW figures suggest. Midrange of the M140i is also stronger but the top end of the M2 is slightly better.
Looks like the B58 should be a great platform for tuning.
Appreciate 7
Robin_NL8679.50
DLSJ5500.50
Pentium184.50
Tuscan221.50
chiefneil771.50
      12-21-2016, 02:12 PM   #2
marcusfva
Italy
70
Drives: M2'17 DCT
So even the supposed 400HP for the M2 CS won't be enough to create a real performance gap between these cars.
And about the performance difference between the actual M2 and the Mx40i..we should probably not get into that.
      12-21-2016, 02:19 PM   #3
BruceM
983
Drives: '17 6MT MG M2,930,Jag XKR 5.0
"Performance" is a function of far more than horsepower and torque.
Appreciate 17
Eddien1231849.00
AndrewC198910903.50
filet.M2c782.50
ried791.50
Pentium184.50
BAN_M2C4154.50
iatacs19456.50
Dav3946.50
krizze924.00
      12-21-2016, 02:54 PM   #4
CommitConfirm
United Kingdom
475
Drives: The Bus
Very true!
Having seen the dyno results it kinda stings a bit. I would have liked the M2 to have had a bigger performance gap. I wonder if I would have been just as happy in a well spec'd Mx40i?
On a daily driver I'd trade the better performance at the lower and mid ranges over a higher top end. Maybe they should build a B58 'LCI' M2?
      12-21-2016, 04:19 PM   #5
kiysersosae
kiysersosae's Avatar
United Kingdom
425
Drives: 1M, M2CS, M3CS
Originally Posted by CommitConfirm View Post
Very true!
if bmw reduce the weight of m2 and add 20-30bhp then the performance gap shown on that graph would mean nothing, the m2s power to weight would be far greater than it is now. . Even if they just reduced the weight by 70kg and added no power it would be miles ahead of the m140i
      12-21-2016, 04:20 PM   #6
kiysersosae
United Kingdom
425
So true
      12-21-2016, 07:33 PM   #7
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
Of course there will be a gap with the S55 M2 CS vs the B58 models.
You think the S55 M2 CS will just have 400hp? Think along the lines that how much the M3/M4 S55s had been underrated and you will have a more realistic figure with the CS.
Appreciate 2
      12-21-2016, 07:39 PM   #8
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
If they can reduce more weight and keep it at the same price they would have done it already. Reducing weight means more exotic materials on the car means a higher cost on the car.
To further reduced weight by 70kg is totally unrealistic and even then it won't be 'miles' ahead of the 140i. 70kg is just the weight of a small adult and won't affect much in a straight line acceleration.
      12-21-2016, 09:59 PM   #9
zenmaster
Drives: '17 M2
Very true!
Where have you been? Dynos the same as a 340i which has been out how long now?
Brian_R29.00
      12-22-2016, 02:55 AM   #10
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Speaking as a m2 owner, I am irritated looking at the graph.
1) N55 and B58 put down identical top end. You will think N55’s maxed out small turbo should spool faster as a tradeoff and make better low end torque. Well, it didn’t happen - B58 has longer stroke and higher compression ratio, which significantly helps down low when pressure isn’t built up.
2) Higher compression ratio means greater timing pull at high PSI and thus less efficient power and less tuneability. Well, it didn’t happen - B58 works just as fine at 15psi as N55.
3) Longer stroke means less free revving. Well, it didn’t happen, B58 rev all the way up to 7K rpm, nothing less than N55.
I would like to thank you for using RON99 so the N55 torque didn’t fall on your graph as much as we saw it does elsewhere.
Now you better tell me the 2 dyno weren't performed the same day please
Lemania 2320
Appreciate 2
Robin_NL8679.50
      12-22-2016, 04:14 AM   #11
Robin_NL
S0THPAW
Robin_NL's Avatar
8680
Drives: HS M2 Competition
Exactly @ Sean...
BMW/M limited the M2 in any possible way putting in the 'low end' N55. Good old N54 is way more sophisticated/tunable and 'high end'. Only the sound is nice but for the rest it lacks grunt and power like S55(and high tech engineering)
I'm going to buy a bigger turbo for my N55 next year....
Cheers
Robin
      12-22-2016, 05:08 AM   #12
Imran@Evolve
United Kingdom
5360
Drives: All of them
They were performed on different days.
I wouldn't get too hung up on the figures. The M2 is more than its engine.
      12-22-2016, 06:22 AM   #13
SeanWRT
SeanWRT's Avatar
3179
Originally Posted by Robin_NL View Post
Exactly @ Sean...
Cheers
Robin
I'd try Tune+Downpipe first before anything that's inreversible.
I am surprised there hasn't been more reviews/dyno on that setup it's been half a year.
Lemania 2320
      12-22-2016, 07:07 AM   #14
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Cheers
Robin
Same here. That way I don't have to hear about the superiority of the B58/S55 in CS as compared to the N55. I'm also looking forward to a top end monster.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      12-22-2016, 07:37 AM   #15
marcusfva
Italy
70
Drives: M2'17 DCT
I think if the M2 CS's motor will be developed as the same way as the S55 M3/4, its crank power will be more or less what BMW will declare for it, because the matter about the underrated power of the M3/4 it appears maybe a little fallacy for European view (I've personally seen two dyno tests of two different stock M4 at my local tuner here in Italy and the results were both around 425-430HP crank, with 100RON).
You already surely know this interesting discussion (especially the 6th post):
http://f80.bimmerpost.com/forums/sho....php?t=1206686
And for sure, I know very well that the M2 is not only its motor. I love it at all
      12-22-2016, 08:58 AM   #16
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Yes lets hope so given that there's £20k premium for M2 v M140i.............you could buy an e46 M3 CS with the leftover change !!!!!
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      12-22-2016, 11:05 AM   #17
Nine Lives
Nine Lives's Avatar
United Kingdom
602
Drives: Austin Maxi
Tell me about it,with barely a ciggy paper between 'em
( there's a thing,system doesn't like the word f*g ) in the performance stakes it doesn't take a genius to see which model has the highest take up...m240i included.
bora57.00
      12-26-2016, 12:49 PM   #18
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
I think I'd rather just have an S58..
VCP1390.00
      12-26-2016, 01:05 PM   #19
FogCityM3
FogCityM3's Avatar
497
Drives: M3 (E90) & Porsche GT3 RS
True, the S55 is one of the most egregiously underrated engines in BMW history. Given produces around ~470 bhp based on dynos (at the flywheel), the M2 CS version will probably be around ~440 bhp assuming the same proportion of under-rating.
Someone thinking the B58 will be some bargain engine that produces as much bhp as a dedicated M-engine and BMW will be "under-charging" for it, is simply deluding themselves.
      12-26-2016, 01:29 PM   #20
mmmpassion
24
Drives: M3 E46 6MT, M3 E92 Comp. DCT
It looks like red and green line are from same motor with diff. runs. Sorry to say that.. .
      12-26-2016, 02:06 PM   #21
exmowner
exmowner's Avatar
578
Drives: 22 M3X / 14 GTR
Why would you be sorry, using your obvious vast mechanical logic?
Lmfao
Nice runs, can wait to get my hands on a m2. Perfect winter beater.
Aronis2267.00
      12-26-2016, 03:02 PM   #22
JunkStory
160
Drives: E92 M3, 8V RS3
This example illustrates that the horsepower and torque ratings from the manufacturer is purely for marketing purposes.
Dackelone10512.00
Search this Thread:
Advanced Search
m2
