how to run e85
12-20-2016, 04:18 PM | #1 |
57
Rep 234
Drives: 2012 335is, 2018 M5, 2003 M3,
how to run e85
what does it take to run e85 besides the jb4? would mixing 85 with 91 (having a jb4) blow my fuel pump? if its do able, would you recommenced upgrading the fuel pump?
12-20-2016, 04:29 PM | #2 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
Start by adding 30% E85. Switch JB4 to map 5. Done.
For higher mixtures of E85 you'll need to upgrade your LPFP and add a back-end flash.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
12-20-2016, 04:49 PM | #3 |
530
Rep 2,083
The stock pump starts to crap out around 40% ethanol (E40). I'd start with 30% ethanol (not 30% E85 as mentioned above) and do a log and see how the LPFP pressures look.
My pump was right on the edge with E40 so I upgraded to the Fuel-It Stage 2 pump just to be safe.
2013 135is DCT Carbon Black Metallic |
12-20-2016, 11:32 PM | #4 |
BimmerPost Supporting Vendor
24199
Rep 190,807
I would start with 20% E85 not 30% ... We need to know how healthy your fuel pumps are before putting more pressure on them
12-21-2016, 06:13 AM | #6 |
102
Rep 416
E85 will not blow your fuel pump. The stock pump just can't keep up with the higher fuel demand required when running a mix. I have run E30 on the stock fuel pump and all the way to E65 with a stage 1 pump.
