Ticking noise when idleing
12-19-2016, 12:55 PM | #1 |
128
Rep 451
I was just at the ATM and noticed a strange ticking noise. It went away if I revved it a bit. No noticable performance issues. 2008 335i with about 77k miles. Recently did the walnut blasting. Have not done the belt of WP/t-stat.. no codes.
Thoughts? |
12-19-2016, 01:02 PM | #3 |
128
Rep 451
12-19-2016, 01:28 PM | #6 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Agreed. You guys are hearing the noise from your fuel injectors.
Remove the engine cover and the sounds will be even louder. The ticking goes away when you rev the engine because the RPMS go faster so the clicking becomes a single noise because you can no longer discern the slower pulses. And because the engine gets louder. |
12-19-2016, 02:11 PM | #7 | |
423
Rep 900
12-19-2016, 02:19 PM | #8 | |
423
Rep 900
http://www.bimmerfest.com/forums/sho...d.php?t=715155 |
12-19-2016, 03:13 PM | #9 | ||
327
Rep 960
12-22-2016, 07:36 PM | #12 |
291
Rep 2,189
Mine has a slight ticking noise at idle since I bought it at 23k miles.
Its only on a cold start, doesn't tick right away(usually after 30 seconds after cold start), it goes away at some point as engine warms up and its only at idle if I rev the engine it goes away. I feel its one or two of the injectors.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
12-22-2016, 08:14 PM | #13 |
Driving cars and riding bikes really fast
285
Rep 1,002
Injectors. Totally normal. My car does the same as did my previous 335i.
Someone mentioned taking the engine cover off. It's crazy loud when driving.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
12-22-2016, 10:19 PM | #14 |
204
Rep 1,103
I had a new ticking that started directly after an pil change, walnut blast and spark plug change... Its quite loud any ideas ? it is present at idle and rises with RPM, thought i cant hear it as the RPM rises because of the noise from exhaust.
