Procede Tune vs. JB4, Cobb, ETC.
12-18-2016, 07:55 AM | #1 |
Rep 20
I've been reading that a lot of people are saying the Procede tune is obsolete and isn't very good. I was just wondering why, and what do other tunes (JB4, Cobb, etc) do that the Procede doesn't. Why are they better?
Thanks! |
12-18-2016, 08:44 AM | #2 |
149
Rep 460
Don't forget the MHD tune also. I can only speak to the JB4 and MHD tunes. We have two cars running the JB4 G5 and one running the MHD.
The JB4 is nice because you can change the maps easily through the steering wheel controls on the fly. It also has a lot of other great features such as gauge sweep, logging, code delete and reading, laptop hook up with a cable, etc,... It is also very well supported and updated by Terry at BMS. Drawbacks, I guess would be the initial cost and installation, although in reality these are pretty minor for what you get. The MHD is not as versatile in that you have to download different maps at a cost depending on what changes you make to your car such as going kittyless, bigger snails, intercoolers etc,.. The program is also car specific. Other disadvantages are reporting and can't change maps as easily although with the Torque app you can log and see what your engine is doing. Advantages on the MHD are the initial cost, ease of installation (you update from your phone). If your not planning to mod your car all the time I'd probably go with the MHD. Regarding the Cobb and Proceed those platforms have seemed to go by the wayside so personally I wouldn't consider either. I've hear d too the Cobb is no longer supported. In the end all will give your car quite a "boost" and beat the stock tune by a mile. I would recommend researching each tuner option and making your decision on what best suites your needs. |
N54wayne7.00 |
12-18-2016, 10:15 AM | #3 | |
Rep 20
12-18-2016, 10:40 AM | #4 |
312
Rep 766
I know it gets a lot of hate, but even if I were starting from the beginning, I would still choose Cobb. It may just be my bias but I f...ing love me V3 Accessport,& haven't had any problems since installation. AlthoUgh I do preventative maintenance religiously... Other tunes are still fine, Procede, JB4,MHD. But for my goals, Cobb V3 wth full bolt ons was 👍👏 perfect .
Chris@VargasTurboTech1933.00 N54wayne7.00 |
12-19-2016, 10:10 AM | #5 | |
3441
Rep 79,211
The problem is the company who provided the Procede no longer updates the software as the platform grows. This is not to say you can't install a procede and run it, you certainly can. However, if you are going to push past the limitations set within, that's where you will really find issues. The PROcede can currently run a typical FBO car on pump gas or methanol injection. Anything beyond that would be a limitation. They did some development with upgraded turbo's but I'm fairly certain they won't work well out of the box. Other tunes like the JB4 and MHD are now geared towards the new modifications of the platform, like E85, upgraded turbo's, back end flashes, ETC. At this point, if you have a procede handy and just want to dip your feet in, it's a good starting point for a free tune. However, you'll soon find limitations and there will be minimal help in the community as procede users are few and far between these days. You can't buy a procede new anyway, so the only ones left are used. If you are seeking a new tune you may want to consider a Cobb JB4 or MHD instead since there is still not only a following, but current updates from the tuners. Last edited by Jeff@TopGearSolutions; 12-19-2016 at 10:46 AM.. |
N54wayne7.00 |
12-19-2016, 10:21 AM | #6 | |
296
Rep 1,515
Drives: Ever changing fleet
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
12-19-2016, 04:10 PM | #7 |
BimmerPost Supporting Vendor
24199
Rep 190,807
JB4 gets new updates on monthly basis, Vishnu Tuning( the company that produced Procede) has stopped support years ago. Nothing wrong with the tune, it is simply outdated
12-21-2016, 07:31 AM | #8 | |
133
Rep 4,764
> -----Original Message----- From: openflashsupport@vishnutuning.com Sent: Wednesday, August 28, 2013 2:57 AM To: Scottp999 Subject: Re: Need ROM support for I761S Here you go Scott. This should work for you. Basic fuel flash for Procede use. Speed delimiter is disabled. Sorry it took so long... shiv > Just speed limiter off. Thanks. > > -------- Original message -------- > From: openflashsupport@vishnutuning.com > Date: 08/27/2013 8:02 PM (GMT-05:00) > To: Scottp999 > Subject: Re: Need ROM support for I761S > > No problem Scott. I can probably have a fuel flash rom for you > tonight. What other options would you like? Cat code disabled? >> >> -----Original Message----- From: openflashsupport@vishnutuning.com >> Sent: Monday, August 26, 2013 8:17 PM >> To: Scottp999 >> Subject: Re: Need ROM support for I761S >> >> Hi Scott, >> Still working on the xdf. The data in the rom is VERY different from >> other rom version which is making it very time consuming to locate all >> the tables. I'm about half way done right now. Chances are that i'll >> be just giving you tuned roms to test at first since going through an >> creating an XDF will take a lot more time. >> > >> Sounds good. The fuel flash rom is the priority to use with Procede >> rev3, RB turbos, 93octane, and meth injection. Appreciate you >> continuing to put time in on these to get the xdf's out eventually. >> >> Thanks, >> Scott From: Scottp999 Sent: Saturday, August 17, 2013 3:59 PM To: openflashsupport@vishnutuning.com Subject: Need ROM support for I761S Shiv, Here is my original ROM file attached. Thanks, Scott Last edited by scottp999; 12-21-2016 at 07:42 AM.. |
N54wayne7.00 |
