12-16-2016, 11:16 AM | #1 |
25
Rep 68
Coding Bang & Olufsen
I didn't get a definitive answer on the M2 forums, so thought I would post here to a much larger audience
I have a 2017 F87 with HK sound. As you guys know our HK doesn't come with the L7 surround or the EQ like on some cars So I coded the B&O option using this - HU_NBT2 3000 -> HIGH_END_AUDIO_MENUE set to: volle_insz but I am not hearing a difference in my car. Yes, it shows in iDrive, but it takes ~20 seconds to change from Studio to Expanded and vice-versa. I have a feeling that because our cars didn't come with the L7 Surround setting, we may not have the DSP for this? Anybody else coded this and have any feedback? |
12-16-2016, 12:10 PM | #3 | |
25
Rep 68
I was really just looking for confirmation that we don't have the right hardware to support the feature. I guess our HK hardware is different than the F30 HK hardware... Thanks! |
12-16-2016, 02:27 PM | #5 | |
25
Rep 68
From reading it had seemed that HK w/ the L7 surround feature was able to code and use the B&O feature successfully. I just wasn't sure if the L7 surround was required for this coding to be successful. Learned about this coding here - http://f80.bimmerpost.com/forums/sho....php?t=1322442 I used to have an F80 so I still hang out there occasionally Last edited by japanaltaf; 12-16-2016 at 02:35 PM.. |
12-16-2016, 11:12 PM | #6 |
191
Rep 314
In the cars with L7 or B&O the DSP happens on the amp not the headunit. As such, the headunit only sends the settings to the amp over the optical cable. Since the HK in the F2X platform is fully analog, turning on any L7 or B&O DSP codings will have no effect.
japanaltaf25.00 |
12-17-2016, 12:19 AM | #7 |
25
Rep 68
Thank you Gabrola! This is exactly the information I had been looking for Now I know why there was no difference in sound between Studio and Expanded. I will be reverting this coding back!
12-17-2016, 06:04 AM | #8 |
454
Rep 986
good luck on recoding, sorry i didnt have a definitive answer.
japanaltaf25.00 |
07-13-2017, 06:33 PM | #10 |
356
Rep 688
Drives: 22 TR X3MC
Can this be done on an F30 with CIC nav?
2022 X3M Comp
2013 335i xDrive (Sold) |
