Hiccups when starting cold and sometimes when warm
12-16-2016, 05:51 AM | #1 |
55
Rep 266
Hey peeps,
I've noticed lately that when I start my car, it will have this intermittent hiccups while idling and warming up. It sort of resembles misfires but then it settled down. I have ran Carly for BMW several times and I do not have any misfire, etc faults. - Spark plugs are new - Coils, as far as I know, are still original coils (car has 145K miles) - Walnut blasting was done 46K ago, so this is due for a nice blasting. Could my hesitation at idle be fouled up intake valves? Or can I still have bad coils and not throw any codes? I am thinking of purchasing all 6 new Delphi coils but not sure if I should wait until codes relating to bad coils start popping up. I am ordering the walnut blaster kit today, because I know this is due and needs to be done. Any help will be appreciated. Thanks!
2007 335i E92 FBO | MHD Stage 2+ 93 octane | xHP Stage 3 | Fuel-It! Stage 2 LPFP | VRSF 7" FMIC | VRSF Catless Downpipes | ER Chargepipe | HKS SSQV4 BOV | Ultimate Racing CAI
12-16-2016, 07:05 AM | #2 |
393
Rep 1,371
Sounds like it could be injectors.
AviatorBimmerFL55.00 |
12-16-2016, 07:58 AM | #3 |
43
Rep 301
injectors
12-16-2016, 08:08 AM | #4 |
55
Rep 266
Injectors? Ouch!
12-16-2016, 08:14 AM | #5 |
Liberty or Death
60
Rep 90
Drives: 2007 E92 335i
Check your spark plugs and see if any of them have a strong fuel smell. Easy way to spot a leaking injector. I had a similar problem, and fresh coils and a walnut blast solved my problem. 2007 with 95K miles, still on the original injectors. Good luck.
2017 BMW 340i
2007 E92 BMW 335i 2007 E90 BMW 335i - Sold |
12-16-2016, 08:23 AM | #6 | |
55
Rep 266
1. Walnut blast 2. Coils 3. Injectors Hopefully 1-2 fixes the issue and 3 can hold strong a bit longer.
12-16-2016, 09:07 AM | #7 |
105
Rep 544
I'm having same issues, I have new plugs, coils, fuel pump. Quick way to check your injectors is to leave the car sitting overnight took out plugs see if they were wet or smell like fuel and nothing also if you can datalog your afr for each bank when you letting off the throttle it should go to a number like 234 I think instantly and stay there. Leaning towards intakes valves. It's been a while since I had my valves blasted.
