Kick down??? manual mode
12-15-2016, 07:02 AM | #1 |
114
Rep 399
Hi guys,
Just a few questions question I drive my car in manual mode( 6 spd auto) pretty much all the time is this an issue with the trans or anything? Also is there a way to disable the kick down? How to you guys dyno the car? Pretty dumb IMO the car even does this. Thank you |
12-15-2016, 08:15 AM | #3 |
707
Rep 2,448
BMS sells a kick down blocker if you don't go with MHD. Full throttle can be the pedal all the way to the floor resting against the kickdown but not engaging the it. Just practice with your car off.
12-15-2016, 08:18 AM | #4 |
114
Rep 399
^^^ Thanx I didn't know that you where WOT without the pedal all the way to the floor. I guess I thought the block behind the pedal was a gas saving thing like in my moms VW. Thanx for clearing that up.
12-15-2016, 03:12 PM | #5 |
217
Rep 245
Kickdown is handy in manual mode since it's the only way to quickly drop to the lowest possible gear. In auto mode however, it is completely stupid and does nothing other than slow you down and shake you up.
12-15-2016, 04:20 PM | #6 |
232
Rep 649
Drives: F80
its nifty when you want to be in 3rd to pass someone but are in 6th, and like someone else said you will get used to it if you practice a bit with it
12-15-2016, 07:08 PM | #7 |
396
Rep 1,210
I have one of the BMS blockers as I found it difficult to not hit while drag racing. MHD is a new option to remove the functionality as already stated. You do have to keep in mind if you are in 6th and want to pass grab a paddle so you don't bog the engine.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
12-16-2016, 07:20 AM | #9 |
Came to the N55 Darkside
1112
Rep 12,740
Johnny Boost323.50 |
12-16-2016, 09:03 AM | #10 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Why wouldn't you just hit the paddle? If you are in manual mode you are using them anyway.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
12-16-2016, 10:50 AM | #11 |
232
Rep 649
Drives: F80
12-16-2016, 12:29 PM | #12 |
245
Rep 1,595
So in manual mode your car will drop from 6th gear to 3rd gear just from hitting the kick down? Are you sure you aren't talking about drive or sport mode?
12-16-2016, 12:59 PM | #13 | |
232
Rep 649
Drives: F80
I do have the alpina flash if that makes a difference but in the 6A, if you pull the paddle three times in quick succession it lags between the shifts and feets jittery, if your in Manual-6 and click the kickdown pedal itll execute all 3 shifts very quickly and smoothly giving you third gear and accelerating up, this is assuming your on the freeway cruising in Manual-6. Normally I dont use the kickdown unless for whatever reason I want to go alot faster then really necessary, usually one downshift to 5th is sufficient to pass anyone on the freeway smoothly |
12-16-2016, 01:27 PM | #14 |
217
Rep 245
I have the regular 2011 AT and when I pull the paddle three times in quick succession it ignores most of my pulls and throws me into some random gear, regardless of mode (manual, sport, auto). It does not count clicks -- I have to pull, wait for the gearchange to complete, then pull again and wait again,....
Flooring the pedal in auto/sport intelligently drops to the best possible gear. Hitting the kickdown in any mode blindly drops it to the lowest possible gear, not the best. It might shift to a gear that's exactly at redline and then immediately have to shift again. Ideally the kickdown should only work in manual mode and it should kick to the best gear, not the lowest. But apparently no one at BMW ever thought about it or actually drove the car. |
