12-13-2016, 09:18 PM | #1 |
3179
Rep 2,577
To begin with, I was one of those that recommends against MPE in terms of gains for money and I still am, yet I have taken the plunge (will be installing in early Jan) regardless of the gains for money and words getting around that how it drones at 3K, because of how much I love my car and want aesthetic & acoustical improvement from OEM parts to add to its perfection.
Reading those drone threads, I'd be lying if I say I wasn't concerned. http://f87.bimmerpost.com/forums/sho...php?p=20977561 http://f87.bimmerpost.com/forums/sho...365&page=6 I noticed MPE removes the resonator from stock system. So I have been thinking if it's going to be a good fix to drone if we retain the stock resonator and only install the MPE muffler. If the system turns out no drone but too quiet, we can stay in track mode all the time by unplugging the harness. From the pictures below (borrowed from one of the members here), I think it can be done by finding a good cut point behind the resonator. What do you think? Also, please comment on the drone as it is and if you can or cannot live with it.
Lemania 2320
01-02-2017, 07:28 AM | #3 |
273
Rep 486
With ASD off, it's much quieter. That having been said, T minus 1 week until I'm going to see DetailersDomain M2 with Akra. If it truly doesn't drone, I'm going to switch. I hate throwing money away, but I cannot live with it. I got mine port installed so I'm SOL regarding resonator without the hassle of someone selling their stock exhaust.
The drone is irritating because it happens during normal acceleration as well, not just cruising. Driving around town, hit 2800 RPM, drone, shift. I guess it has the side "benefit" of giving me a shift point but it makes me want to Though you might want to wait until the new version comes out, assuming that's happening. http://f87.bimmerpost.com/forums/sho....php?t=1335607 |
01-02-2017, 09:12 AM | #4 | |
3179
Rep 2,577
Never heard drone report with F87 akrapovic system, high confidence you'll be good. Keep us posted how you like it. For me the only reason I pass Akrappvic is its "fake" dual pipe design (a real one should have two downpipes). There is no need for splitting the flow and thus increasing the diameter AFTER DP. It only make senses to me it should have a slightly smaller diameter if anything to increase the flow rate as gas gets cooled down and volume shrinks. I am sure Akra knows it better and I most certainly am wrong. In 2 weeks my MPE will be installed, if it drones, I'll then try put back resonator. Will let you guys know.
Lemania 2320
01-02-2017, 09:30 AM | #5 | |
4399
Rep 2,856
Drives: BMW M2 CSL Turbomeister
MR |
04-03-2017, 09:43 AM | #6 | ||
58
Rep 149
2016 M2 | LBB | Executive Pkg.| M Performance Exhaust | Dinan CAI | Fabspeed SportCat | standard-h.com | @standardh_
04-03-2017, 02:28 PM | #7 | |
3179
Rep 2,577
In fact, drone grows on me over time. To be frank, I'd rather have it...
Lemania 2320
04-04-2017, 03:55 PM | #8 |
17
Rep 146
Just wondering, as I'm looking for an new exhuast. I always thought that MPE was very similiar to stock once its closed/off by the bluetooth switch, and once engaged/on its really loud - like two exhaust in one?! But reading now about drone, neighbours, not for everybody etc. makes me wonder. Is the performance exhuast always much louder than stock? And what does the blueooth control do then?
Thanks! |
04-04-2017, 08:04 PM | #9 | |
3179
Rep 2,577
I confirm MY2017 ASD is a good improvement from 2016, but still in-cabin is a much better place without it.
Lemania 2320
02-16-2018, 07:44 PM | #10 |
#savethemanuals
2431
Rep 1,970
Did you install with the stock resonator fitted to MPE?
02-16-2018, 09:53 PM | #11 | |
3179
Rep 2,577
Lemania 2320
02-16-2018, 11:17 PM | #12 |
#savethemanuals
2431
Rep 1,970
02-17-2018, 05:04 AM | #13 | |
1836
Rep 4,203
Also I have proven on the dyno runs that the exhaust makes HP even though BMW claims 0. They are just being conservative like they do on power output |
bollinm25.00 |
02-17-2018, 05:49 AM | #14 |
3179
Rep 2,577
No I didn't do anything. I mean it, 3k drone isn't that much of an issue it's just a little bit louder than normal at that rev ranges and I think it adds to car's character. I wish I had it back.
Lemania 2320
02-18-2018, 09:17 AM | #16 |
1787
Rep 1,718
Finally was able to get my car out on the road the other day...been waiting for broken leg to heal and a break in the weather (no pun intended)...noticed the drone a 3K right away. I also have FS DP so it seems really loud and annoying at 3K. Not impressed. I tried all the "modes" and Traction mode seemed to be the best from a drone perspective, but not from a throttle response perspective, sport+ seems best for that...but drones like a b!tch at 3K. Because I'm still in the break in period I can't really go too much higher than 3K in the rev range. I have not coded ASD off as yet, because I wanted to drive the car for a bit first so I can tell if I notice a difference, (on vs. off).
For those that have the MPE FS DP set up AND have coded ASD off, does it markedly improve the drone? Have you noticed that after a certain amount of kilometers, that the drone reduces (i.e. exhaust break-in)? I had the MPE on my F30 and I do seem to remember it changing a bit over the first 5-10 thousand kms. I may have to switch exhausts if this doesn't get better over time. Too bad, because I like the look of the MPE. |
02-19-2018, 10:09 AM | #17 | |
273
Rep 486
02-19-2018, 11:14 AM | #18 |
1836
Rep 4,203
07-25-2020, 07:34 PM | #19 | ||
201
Rep 425
08-23-2020, 03:00 AM | #20 | |
293
Rep 644
Drives: 2018 6mt AW m2
08-27-2020, 05:21 PM | #21 | |
1787
Rep 1,718
08-28-2020, 04:00 PM | #22 |
293
Rep 644
