BMW M5 F90 (2018+) General Forums F90 M5 General Forum    M5 gets a switchable AWD ?!
      12-12-2016, 02:59 AM   #1
4BMWGarage
Germany
371
Drives: BMW
BIMMERPOST
     Featured on BIMMERPOST.com
According to bimmertoday the M5 will be a 4x2. This means that you can switch between four-wheel drive and rear-wheel drive at the push of a button.
source: http://www.bimmertoday.de/2016/12/12...uf-knopfdruck/
The complete article translated:
"The change of the BMW M5 F90 to four-wheel drive is supposed to make the power sedan from Garching even more appealing, but some customers are annoyed by the absence of the rear wheel drive, but there is good news for this clientele, because if our information is correct The new BMW M5 F90 at the push of a button: Depending on the driving mode, the driver can decide whether he wants to distribute the power of the V8-Biturbo to all four wheels or prefer the full power on the rear axle.
We assume that the corresponding mode with pure rear wheel drive can also be stored on one of the steering wheel buttons. If you want to be particularly dynamic, you can activate the driving mode for maximum driving pleasure with two short thumb movements and also enjoy the BMW M5 F90 with rear-wheel drive.
The option of rear-wheel drive at the push of a button is designed to take the wind out of the sails that make the new BMW M5 F90 less exciting than its predecessor due to its standard all-wheel drive. In many situations, however, the four driven wheels will offer advantages, not least in terms of acceleration. On dry asphalt, a maximum of 3.5 seconds will pass before the three-digit speeds are reached. Apart from this, the all-wheel drive naturally offers great traction advantages on slippery ground, which is to open up new customers in the alpine area and the North American Snow Belt.
The power sedan is powered by a further developed V8-Biturbo with a displacement of 4.4 liters, which is expected to press almost 600 hp on the crankshaft at the beginning of the market in 2018. Later variants such as the BMW M5 CS will continue to turn at the power screw and underpin the special wheel of the BMW M5 as a sports car in the business dress.
In order to be able to look even better on stretches with tight corners, the M GmbH has also parted with the weight of the BMW M5 F90. The top model of the new 5 Series G30 not only benefits from all lightweight construction measures of the large series, but also adds additional elements with elements such as the standard carbon roof. On the bottom line, the M5 should bring a few kilograms less than the predecessor despite the more complex drive train with all-wheel drive and more extensive series equipment. It goes without saying that the experts at M GmbH also do a lot of fine work on the chassis and thus also want to improve performance."
Appreciate 4
Bosozoku693.50
Niko ZV118.00
      12-17-2016, 12:40 PM   #2
Eddien123
Drives: F30 335 6MT
This defeats the purpose entirely. For me, AWD is stupid for a performance car because it ADDS weight. Provided the weight distribution is good and the AWD is rear biased, it won't under steer. A RWD setting just means your car is rwd with a stupid amount of weight added for no reason. I mean honestly...
STR8-6IX536.00
      12-17-2016, 12:56 PM   #3
Chris330
Chris330's Avatar
United Kingdom
210
Drives: 340i F31
I actually think that's a great move. Give the driver the option and make it the most useable daily performance vehicle available
X5 40d M F15 - July 2018 - Space Grey
Mini JCW F56 - June 2018 - Rebel Green
Previous: 340i M F31 2016-18, 2015-16 435i M F32, 2013-15 330d M F30, 2011-13 Mercedes C250, 2008-11 320i E92
Appreciate 8
Bosozoku693.50
YungDro1088.00
Refujeet262.50
DD335i116.00
      12-17-2016, 01:05 PM   #4
rundmc_92
Drives: 2008 E82 135i
I understand what you're saying, I really do. But how many people wish they could take their performance car out in mediocre ->snowy weather instead of keeping them locked away in a garage during the winter (probably not many I know).
But, if all of a sudden you had the ability to feel semi-confident in inclement conditions, you might be convinced to go throw down out there. It allows you to use your badass M5 for a longer period of time anyway, so where's the harm in that?
Appreciate 4
      12-17-2016, 01:11 PM   #5
ron_jeremy
ron_jeremy's Avatar
Norway
513
Drives: 13' F25 X3 20d & 16' i3
Well, there is a limit hos much power two wheels can handle. M wouldn't go that route If they had a choice. This way you can have a choice, And that's great
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat
X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive.
Appreciate 3
Bosozoku693.50
YungDro1088.00
      12-17-2016, 01:15 PM   #6
mvigod
mvigod's Avatar
Drives: 2021 X5M
Definitely would need snow tires because pretty sure M5's will all ship with performance summer tires.
To the other poster above......
I like this new strategy. AWD is great for faster sprints to 60 or 100. Also will help pull the car much FASTER around the track. Witness the 918's performance on track and know the AWD was instrumental to beat the P1 and LaFerrari all which had MORE horsepower and were lighter! AWD is a big benefit in all aspects. Don't let the small amount of weight fool you as that is a very worthwhile tradeoff unless you prefer to go slower
Appreciate 5
      12-17-2016, 01:30 PM   #7
Eddien123
Drives: F30 335 6MT
No I understand that and adding AWD is fine. But BMW claims this is a compromise for those who want one or the other and it's not. I avoid AWD because I don't like an added 3-400lbs to the car. Driving an AWD car in RWD mode is pointless. You're still carrying the weight.
Appreciate 2
6ixSpd5996.50
tetsuo1111224.00
      12-17-2016, 01:32 PM   #8
Eddien123
Drives: F30 335 6MT
There is no harm in an AWD option. I encourage that. But for those who want a lighter more nimble rwd car that's no longer an option. (Yes I understand the M5 was never "light" but adding this weight to just drive it around in rwd anyway is pointless)
Provide two different models one with RWD one with AWD.
      12-17-2016, 01:43 PM   #9
rundmc_92
I'd like that, though I don't see the BMW bean counters letting the M division getting away with that unfortunately
      12-17-2016, 01:44 PM   #10
Mad One
Jersey
11
Drives: F80 M3
My local stealer told me this months ago. Posted it somewhere on the forums. Makes complete sense with the huge torque at low revs that modern turbo engines produce. I've just read Januaries Car magazine (UK) about the new AMG E63 S which also 4 wheel drive and they loved it. It the same issue, a new mid range 5 series beat the equivalent E series, so looking good for the M5.
      12-17-2016, 01:44 PM   #11
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
This makes perfect sense and M division alluded to AWD years ago. Hell the SAV M's have always been AWD. Besides today's M cars are making too much low end torque for RWD (ex F8x).
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
Bosozoku693.50
      12-17-2016, 01:46 PM   #12
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
The people whining about AWD in the new M5 fail to fully grasp that BMW is being left behind due to all of the competition putting down so much more power to the wheels because of AWD. You want BMW to stay RWD but that would mean not being able to fully compete with everything else. If this option to be both AWD and RWD is real, it would mean the best of both worlds and you will have to live with the extra weight.
Get with the program or get left behind.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
Appreciate 5
YungDro1088.00
Bosozoku693.50
F32Fleet3539.50
mvigod179.50
      12-17-2016, 01:51 PM   #13
JRobUSC
Drives: Mineral Gray 2019 330i xDrive
I don't know how much the AWD system would add on an M5, but the weight difference between a 750i and a 750i xDrive is only 121lb according to BMWUSA.com. While 121lb is more than 0lb, I would consider that a pittance of a penalty considering the performance benefits, not to mention the year round usage. I don't see many people complaining about AWD on the Porsche 918 and 911 models.
Appreciate 3
      12-17-2016, 01:52 PM   #14
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
In other words: DRIFT MODE!
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
Appreciate 3
      12-17-2016, 02:04 PM   #15
sahajesh
sahajesh's Avatar
United Kingdom
2290
Drives: 2021 G05 X5 40i Tanzanite Blue
WTF?
Appreciate 4
YungDro1088.00
Bosozoku693.50
M3JHWK75.50
      12-17-2016, 02:14 PM   #16
DR_G
DR_G's Avatar
17
Drives: M4 + M Performance
I have to disagree, there's plenty of AWD performance cars out there; in this case BMW are already shaving what? 100kg off the base car, and M are potentially giving you the option of tail happy fun-times, but with the ability to switch back to AWD?
Sounds like a winner, already really like the look of the new 5 series, looking forward to seeing what the M5 brings.
Appreciate 4
YungDro1088.00
Bosozoku693.50
f30nynj83.00
      12-17-2016, 02:24 PM   #17
e90///M3
71
Drives: E90 M3
I think this is a good move for the m5. It does have a lot of power for the rear wheels ... and besides I highly doubt the added weight from this new technology will be a deal breaker for an m5 shopper.
Bosozoku693.50
      12-17-2016, 02:37 PM   #18
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
Honestly, the M5 is not a M-car anyway. Sporty family car, yes. Sports car, no. Too heavy.
Bosozoku693.50
      12-17-2016, 02:43 PM   #19
YungDro
1088
Drives: -
thread closed....
Appreciate 2
Bosozoku693.50
      12-17-2016, 02:52 PM   #20
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Find a good 1985-1988 E28 M5 then.
It's a featherweight at 3,417 lb. Less than an M2.
Because you're not hauling around all those modern luxury goods.
Let's see now. The outgoing F10 M5 weighs about 4,288 lb.
Here's the math: 4,288 - 3,417 = 871 lb.
You'd be saving 871 lb. and probably a lot of cash as well.
Note: The G-generation M5 might weigh less than the F11, but will probably cost more.
Source (for M5 model weights): https://en.wikipedia.org/wiki/BMW_M5...2.80.931988.29
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      12-17-2016, 03:15 PM   #21
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Could not agree more with comments about Porsche 918 Spyder and its AWD drivetrain being the differentiator.
mvigod179.50
      12-17-2016, 03:38 PM   #22
DominNYE24
Drives: 2013 F30 335i
Just buy some decent snow tires, it won't add any weight and you guys would be fine in any conditions! Leave M5 RWD as it should be!!
tetsuo1111224.00
Search this Thread:
Advanced Search
