e85 and winter weather do not mix
12-09-2016, 08:43 AM | #1 |
77
Rep 154
I was having a blast running full e85 all summer. Yesterday, the temps dropped to 17F and the car would not start. it would fire up and die out immediately. Luckily I did not miss work and was able to have someone help me push the car into my garage. Is there any mix that can work in the winter or is it just better to stick to pump gas?
Hexon RR700's, Hexon Inlets, MMP Outlets, VK Motorwerks Catless downpipes, VK Motorwerks Oil Cooler kit, BMS CAI, Whey Protein powder, Wagner Evo 2 Competition FMIC, 3.5 bar maf, BMS catch can, ETS Chargepipe with Tial BOV, Fuel-It Stage 3 Platinum kit with PI. All tuned by Ken@Wedge! Suspension: Stock 6" XI lift kit...11.13@133.2mph. Speedtech Gtx3582r single in the works.
12-09-2016, 08:59 AM | #2 |
Guest
Rep n/a
Drives:
Get your tuner to adjust the new cold start tables maybe.
FWIW, I'm on ~E65 and have zero issues down to 32*F so far on the OTS E60 MHD map. It should be getting much colder here in the coming weeks though, so time will tell. |
feuer4275.50 |
12-09-2016, 10:40 AM | #3 |
202
Rep 649
32 and 17 is a huge difference when it comes to E85. You can make some tune adjustments to help it out, but its always going to be a bitch
17 M3 Comp
12-09-2016, 11:46 AM | #5 | |
391
Rep 532
12-09-2016, 11:52 AM | #6 |
456
Rep 6,478
There's a point of rapidly diminishing return when it goes from cold to COLD...but check out the latest cold start tables in the updated XDF. They work great!
12-12-2016, 05:41 PM | #10 |
319
Rep 891
Ran e40 in less than freezing with no issues.. You could tell it started with a little struggle but not to a measurable amount.. The kind of thing where you just know how your car reacts on a day to day basis to everything
Formerly Ian_N54 - @b1mmr
12-12-2016, 11:46 PM | #11 |
77
Rep 154
I was able to pull the car in the garage and put a space heater on to warm up the room. I got the car started and added 93oct. Dropped the content down to E30. No problems starting up now. Car runs great.
12-13-2016, 03:48 AM | #12 |
163
Rep 466
anything above e60 really sucks when it come to cold starts when its under 40 degrees.
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
12-13-2016, 10:25 AM | #14 |
177
Rep 96
The Fuel (Start) table I added fixes this issue 100%.
12-13-2016, 01:50 PM | #15 |
37
Rep 433
Drives: 335i wagon, Pure Stage 2+PI...
MHD should make you a deal so it can be incorporated in the app and as easy to set as the burble option (without negative effects lol)
FBO 335i N54 WAGON
Pure Stage 2 Turbos Port Injection Stage 3 LPFP E85... |
feuer4275.50 |
12-13-2016, 03:05 PM | #16 |
406
Rep 574
No this should definitely not be a flash option. This should be tuned like any other table and modifed to reflect the tune, be it pump, E30, E50 or E85. It's not just for cold starts that's just where you need it most with ethanol fuels.
bradsm87594.50 |
12-14-2016, 10:51 AM | #17 |
202
Rep 649
You guys don't even know what winter is in Australia. E85 in -20 to 10 degree winters lots of us in the US have to deal with ain't happening. Especially in places where they keep high concentrations of ethanol in the gas year round.
17 M3 Comp
12-14-2016, 12:17 PM | #18 | |
37
Rep 433
FBO 335i N54 WAGON
12-14-2016, 03:09 PM | #19 |
Guest
Rep n/a
Drives:
Agreed; no slider necessary. If the current OTS maps were updated with the proper table edits, that would be peachy keen
12-14-2016, 03:15 PM | #20 |
380
Rep 1,497
I just decided to stay with pump gas.
A. Less power and safer B. Octane isn't all that good during winter months C. Alot more traction as it has less power D. Cold starts don't suck |
12-14-2016, 03:53 PM | #21 |
Guest
Rep n/a
Drives:
12-14-2016, 03:58 PM | #22 |
Rep 25
Do you know how long the E85 stays good? I have had my car in a shop for 10 weeks now, with E60 in my tank. As winter is coming, one thing is starting the car but.. what about its quality. Does it deteriorate? Can it damage something after several weeks?
