OK to Clean N54 Carboned up Spark Plugs?
12-07-2016, 08:27 AM | #1 |
149
Rep 460
Our 2007 335i had injectors #1 and #3 stick open and cause the car to run rich. I ended up switching out all six injectors to index #12 ones and coding with INPA.
The spark plugs have 7K miles on them. When I pulled them #1 and #6 spark plugs they had lots of carbon build up on them. I went ahead and used sandpaper and gasoline to clean the electrodes off. In your opinion is this still an acceptable thing to do? I know the N54 engine can be pretty finicky. Running it in map 0 this week just to make sure there are no issues. Haven't gone back to map 5 yet. |
12-07-2016, 08:55 AM | #2 |
Driving cars and riding bikes really fast
285
Rep 1,002
I would have used a spark plug cleaning device. It's hooked up to compressed air and uses light sand blasting to clean the entire plug. We used them all the time on our 2-stroke dirt bikes.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
whyzee1251678.50 |
12-07-2016, 12:47 PM | #3 |
172
Rep 392
Spark plugs for these cars are damn cheap, I would just get a new set from RockAuto or something
Last edited by r4dr; 12-07-2016 at 04:14 PM.. Reason: Spark plugs not injectors, doh |
12-07-2016, 03:22 PM | #4 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
$200 is cheap for an injector? Even when they used to be $120 that was still a lot for an injector compared to most cars.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
12-07-2016, 04:14 PM | #5 |
172
Rep 392
Wow I totally blanked, I meant spark plugs.
Yeah, injectors are not cheap by my standards. |
Antetokounmpo1551.50 whyzee1251678.50 |
12-09-2016, 06:52 AM | #9 |
2341
Rep 3,539
If he is able to clean it of without damaging the spark plug, there is nothing wrong with that.
That plug will still function normally. So if you want to throw money away get new plugs. If the one you cleaned works fine, why change it? |
12-09-2016, 08:34 AM | #10 |
149
Rep 460
We've had a couple misfires- the car goes briefly into limp mode. Crazy thing is there are no codes when we check it. I've already replaced the coils and injectors as well as the mosfets. We have both the torque app and JB4 to check it.
The only thing that is original now are the oxygen sensors and cleaned spark plugs (with 8K on them). I'm just going to go ahead and get six new plugs. |
12-09-2016, 09:03 AM | #11 | |
Guest
Rep n/a
Drives:
Mod list? |
12-09-2016, 09:56 AM | #12 |
149
Rep 460
12-09-2016, 10:37 AM | #13 | |
Guest
Rep n/a
Drives:
http://www.ebay.com/itm/271955436860 The colder heat range may help with your misfires; it certainly won't hurt in any way so it's a win/win regardless. |
