12-05-2016, 02:18 PM | #1 |
183
Rep 791
Vorsteiner vff103s
Would like to know if the vff-103s fit the m2?
Would love to see some images.
YMB F80 M3 DCT (Gone but never forgotten)
AW F87 M2 6MT (Current whip) |
12-06-2016, 09:12 AM | #2 |
Space Force - 4 Star General
11456
Rep 3,264
Yes,they will fit. I dont have first hand experience, but I have several quotes from wheel shops that wanted to talk me into the 103s when I came asking about the 101s. The VFF-101 is not listed for the M2 but the VFF-103 is. Good luck!
M2wolf182.50 |
12-06-2016, 02:44 PM | #3 | |
183
Rep 791
Am wondering is it because of the looks?
12-07-2016, 05:05 AM | #6 |
183
Rep 791
Would be good if you can send some pics. Which vffs and colour?
12-07-2016, 08:54 AM | #7 |
34
Rep 46
12-07-2016, 01:09 PM | #8 |
183
Rep 791
Which size?
12-08-2016, 08:40 AM | #9 | |
34
Rep 46
Front 9 x 19 ET24 Rear 10.5 x 19 ET34 |
12-08-2016, 09:44 AM | #10 |
757
Rep 1,835
Drives: 2020 X4M CS
Yeah I have them look at my mod journal
19x9.5 et 22 19 x10.5 etc 35 rear Look and fit amazing. I lowered on h&r springs and nitto nto5 tires 245/35r19 n 275/35/19 |
12-08-2016, 09:51 AM | #11 |
183
Rep 791
Pls share links?
12-08-2016, 10:15 AM | #12 |
757
Rep 1,835
Drives: 2020 X4M CS
http://f87.bimmerpost.com/forums/sho...1254386&page=6
The pics on there are with etc 30s front. I didn't like the flat look of the fronts compared to rear if u skip ahead in journal Ullike see i switched out the fronts to the lower offset...the car is in the shop now. And springs tires were just installed... |
M2wolf182.50 |
12-08-2016, 01:32 PM | #13 | |
183
Rep 791
19X9.5 5X120 35 MM 19X10.5 5X120 35 MM Would you say they will be an ideal for the M2 without spacers? Cheers
12-09-2016, 08:11 AM | #14 | ||
34
Rep 46
I think they have et 24 in those size |
12-09-2016, 02:56 PM | #15 | |
757
Rep 1,835
Drives: 2020 X4M CS
They are more concave than the rears and stick out further...Im getting 15mm for rear so they match better.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
12-09-2016, 03:00 PM | #16 |
183
Rep 791
ET24 being the 19x8.5 size for the fronts?
12-09-2016, 03:03 PM | #17 | |
757
Rep 1,835
Drives: 2020 X4M CS
And after I started performance mods....traction became a real issue...so a 10.5 or even 11" rear with some good traction rating draa radials ('Im going 275/34/19...Maybe even a 285/30/19) Thats what i highly recommend...
12-09-2016, 03:10 PM | #18 | ||
34
Rep 46
The diference betwen 19x10 et 40 from factory and 19x10,5 et 35 it's not like 5mm spacers. It is like 10 mm diference from factory because you are doing the wheel more wide. |
12-09-2016, 03:16 PM | #19 | |
183
Rep 791
Ok, so the fronts from my VFF103s is not ideal. The rears are fine. Which sized VFF103 fronts should I get pls ? Lastly, can I reuse the stock tyres? If not which sized recommend tyres? Thanks!
12-09-2016, 08:02 PM | #20 | ||
34
Rep 46
And you could use the stock tyre |
12-18-2016, 03:30 PM | #21 | |
757
Rep 1,835
Drives: 2020 X4M CS
Its actually like have 11.25 mm spacers....(to be precise) I was doing the math out loud to help people...5mm from lower offset...then a 1/2 inch wider RIM means the RIM will have .25 inches extra sticking out and behind....An inch is 25mm my friend....12.5mm extra width from a 10 to 10.5" 12.5/2 is 6.25mm + 5mm lower offset...so total 11.25mm further than stock...and the tire is a 275mm as opposed to 265mm adding 5mm pertrusion on top of the more agressive wheel....so its 11.5mm spacer sitting but bc the tire it will look more agressive like a 16.25mm pertrusion over stock wheels and tires ... But thanks guy for jumping on me instead of taking your time to read my post. And "doing the wheel more wide" or what ever u said. That's not proper English. I hope your foreign, If not you better go back to school, thats like 3rd grade English.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 12-18-2016 at 03:49 PM.. |
12-18-2016, 03:35 PM | #22 | |
757
Rep 1,835
Drives: 2020 X4M CS
Yes as the last poster said 19x9.5 et 22 front, 19x10.5 et 35 rear with stock tires would look perfect. It is what he and I are running.... I was just saying I got too high an offset first and was so unhappy I bought new front wheels... And I was trying to give you an idea where they would sit. It'd be like 14.25 mm spacers front and 11.25 rear. Which is agressive but you wont have to worry about ruubbing,even if lowered as I am, and I even just ordered 15mm spacers for the rear (with a 10mm wider tire too) but measured and rear wells are very big on M2.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 12-18-2016 at 03:46 PM.. |
