N55 help please
12-04-2016, 08:55 PM | #1 |
Rep 13
N55 help please
So basically my car was running perfectly fine went for a car wash stopped over for 5 minutes came back started car and literally whole car was shaking no power amd struggled to even move got it towed to a local specialist who said the o2 sensors needed replacing so done those but still the same issue. Codes are as follows any help would be appreciated.
Thank you |
12-04-2016, 09:46 PM | #2 |
1161
Rep 3,189
Well that is a lot of electrical codes. Has he tried clearing them to see what comes back? I would check the battery and ground. Old batteries cause all sorts of problems, so check it's voltage too.
12-05-2016, 08:41 AM | #3 | |
337
Rep 258
12-05-2016, 11:51 AM | #4 |
305
Rep 1,163
You are getting water somewhere. I had all those codes happen after a 24 hour rain storm. My amplifier was literally sitting in 1" of water.... Water was leaking in through the tail light.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
12-05-2016, 05:37 PM | #5 |
Rep 13
Thanks for the responses so he has tried clearing them but no luck they all come straight back i've also had a new battery within the last few months. I'll get them to dig around the car to check for any signs of water leaks. Anymore advise would be appreciated. Also i had the windscreen replaced not so long ago i'm wondering if the plastic cowling was not put back on properly and correct me if i'm wrong but the ecu sits just under that so would make sense that maybe water getting into ecu although i've never opened the ecu and supposedly its water tight right
12-05-2016, 07:06 PM | #6 |
1161
Rep 3,189
ECU sits under the intake manifold. There is a box with some fuses and wires on the passenger side that can be exposed to water if spmething wasn't seaped right. I would start pulling fuses in the glovebox and see if anything is blown.
12-05-2016, 07:47 PM | #7 |
45
Rep 194
Sounds like possible water damage, or maybe a bad ground.
It says you drive a 330d? If so you posted this is the wrong section.
12' 335i
| CP-E CP | MHD | VRSF DP | ALPINA B3 | |
12-15-2016, 10:06 PM | #9 |
15
Rep 114
Hello!
What you are describing sounds almost similar to what happened to me. After an hour or so of troubleshooting, I found out that my charge pipe had somehow gotten unhooked which caused my car to struggle to stay on and have a really rough idle and throw a code for my MAF Sensor. Maybe check your charge pipe and see if there is any leaks or it that it may have gotten loosened somehow? |
