MHD & Aplina B3 Tranny Flash
12-03-2016, 06:57 PM | #1 |
Ion L.
29
Rep 179
Guys,
Have a questions regarding MHD Tuning Flash.... Currently have Cobb with Alpina B3 Tranny. I plan to switch to MHD Tuning Flash and my question is, can I straight install the MHD Tune Flash with the Alpina B3 Tranny Flash already installed OR do I have to in-install the Alpina B3 Tranny Flash, then install the MHD Tune Flash, and lastly re-flash the Alpina B3 Tranny Flash? Is there a particular sequence for this type of flashes regarding MHD and Alpina B3 Tranny Flash being installed? Any input would be great! Thanks
///Minor Mods///
12-04-2016, 09:44 PM | #7 |
866
Rep 5,450
Mhd and the alpine flash work great together, when I had my giac flash , Rpms would oscillate at high torque loads due to the ecu limiting torque, but tcu allowing more.
Mhd increases torque limits on at with giac flash, so technically you do get a little more performance!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-05-2016, 11:51 AM | #8 |
530
Rep 2,083
To the OP, yes you can install MHD while the Alpina flash is already installed. Just make sure to uninstall the Cobb first, obviously.
Regarding the MHD option, I've tried both with and without the Alpina option and didn't notice any differences. Drive mode sucks ass either way.
2013 135is DCT Carbon Black Metallic |
12-15-2016, 03:47 AM | #9 |
13
Rep 161
First of all ECU (engine) und TCU (transmission) are completly seperate as for manipulating them, so basically you can run Alpina or stock TCU-Flash with every ECU flash (Cobb, MHD, GIAC, ...).
The Alpina flash allows higher torque-limts, so the transmission does not cut power as it does with the the stock flash. The downside is, that in normal "D" mode the shiftpoint are kind of weird, because die Alpina TCU flash expects the Alpins ECU flash with different throttle settings than stock. Therefore you have to adjust the throttle to smooth that out. Is that what MHD does? There is a thread on BB discussing that topic: http://www.***********.com/showthrea...944#post684944 Did anybody apply those pedal/throttle tables of the Alpina TCU within MHD? |
12-15-2016, 04:40 PM | #10 |
3441
Rep 79,211
He may have read it from me. I have a custom map and therefore I can't "SELECT" Alpina during the flash process. Only OTS maps can select it from what I understand.
If you have the option and have the flash, you mine as well check the box though. It doesn't seem to affect anything from what I can tell. Maybe I'm missing something? I'd be happy to learn something new on it. |
12-15-2016, 05:38 PM | #11 | |
287
Rep 595
When would the stock calibration be limiting torque? Is this during shifts only? Or anytime a specific torque threshold is exceeded? Anyone know what those limits/thresholds are? |
12-15-2016, 11:13 PM | #12 |
330
Rep 984
The MHD maps that specify for Alpina flashes are much smoother than the MHD maps that specify for standard flashes. So even if you have the Alpina flash and you flash the MHD map specified to standard flash, it wont be as smooth as the MHD map specified to the Alpina flash.
Wedge care to chime in on this? |
12-16-2016, 09:35 AM | #13 | |
3441
Rep 79,211
Most of the smoothness after my Alpina Flash came back when I reset the transmission adaptations. I can go from 1 to 6th gear and you can't even feel the car shift in D mode. Not sure how much smoother it can get. |
12-16-2016, 10:44 AM | #14 | ||
Guest
Rep n/a
Drives:
http://www.e90post.com/forums/showpo...postcount=7838 http://www.e90post.com/forums/showpo...postcount=6107 etc. |
12-16-2016, 10:52 AM | #15 | |
3441
Rep 79,211
If you're on the OTS maps, users mine as well select it though. Last edited by Jeff@TopGearSolutions; 12-16-2016 at 10:57 AM.. |
12-16-2016, 10:58 AM | #16 | |
Guest
Rep n/a
Drives:
If your current tuner isn't able to effectively modify the tables, find a new tuner. |
12-17-2016, 06:35 PM | #19 | |
184
Rep 2,841
http://www.e90post.com/forums/showpo...postcount=7106 Also just found this one: http://www.1addicts.com/forums/showp...48&postcount=8 Last edited by Ilma; 12-17-2016 at 06:53 PM.. |
12-18-2016, 04:09 PM | #20 | |
3441
Rep 79,211
