11-29-2016, 10:20 PM | #1 |
Moderator
4087
Rep 1,973
G-Power 1st aftermarket parts for the G30 5 Series
Already after market parts for the G30 before its release...
From their website: https://www.g-power.com/news-en/ The new BMW 5 Series is coming – and G-POWER is ready for it! The new BMW 5 Series - with the internal code G30 - is waiting in its starting block to finally replace the current 5 Series F10 models in February 2017. And G-POWER as well has entered the final phase of the product development for the 7th generation of the luxury sedan, so that the broad G-POWER program will be available from launch on. Because despite of all the qualities coming from the manufacturer, there is always room for more individuality, power and dynamic. This begins already with the G-POWER HURRICANE RR forged wheel set that adds an individual tough to the outer appearance of the new BMW 5 Series, but also improves the comfort, handling and last but not least the acceleration significantly by reducing the weight of the unsprung masses with its low weight. Even more dynamic is generated by the G-POWER power output enhancements. No matter if you choose a Petrol or Diesel model with Bi/D-Tronik 2 performance software or the Bi/D-Tronik 5 named external performance module, you’ll just have this vital portion of extra power on top of the standard output that is so much fun. Thereby each of which options has specific advantages. Being a plug and play device the Bi/D-Tronik 5 performance module is placed between the factory ECU and engine. Its highlight is the intelligent feature to remain inactive under partial load conditions, all incoming data passing through without change. However, a demand for full throttle instantly triggers the unique fueling and boost curves that create the additional power output. In parallel with the Bi/D-Tronik 5 module G-POWER also offers their Bi/D-Tronik 2 upgrade, which involves bespoke remapping of the factory ECU. Where the Bi/D-Tronik 5 module is a one size fits all solution, the bespoke remapping procedure of the Bi/D-Tronik 2 conversion allows taking into account your individual wishes vis-à-vis throttle response and powering delivery characteristics to be written into the software. But no matter what option you chose, with both versions all standard diagnostic and engine protection systems remain unaffected. The G-POWER program for the new 5 Series G30/31 is completed by a height-adjustable coil-over suspension and G-POWER exhaust systems – made from stainless steel or titanium - with two or four tail pipes. Unfortunately you’ll now you have to wait until February 2017 in order to enjoy the new G-POWER products, but still pleasant anticipation is known to be the best kind of delight.
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
