TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 11 335i N55 throwing 348A code. Thermostat?
      11-28-2016, 04:21 PM   #1
wtobiason
wtobiason's Avatar
Drives: 2018 BMW M4
I was driving to work today and lost all power. I could maintain speed but no acceleration. The cooling fan was on high too. I contacted Burger tuning with the code my JB4 gave me and they said it was "348A is a thermostat jammed open code"
What could be causing this? Is the thermostat dead or is there somehting else that might be causing this?
Thanks all for your input.
      11-28-2016, 04:22 PM   #2
Peen
Peen's Avatar
41
Drives: 2011 BMW 335i Sedan
Happened to me when water pump went out. Check for coolant under car? Also check for coolant in reservoir.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / VRSF Catless DP / Phoenix CP / YCW Coilovers's 6K-18K / M3 Control Arms / Enkei Raijin 18' Wheels / Michellin PSS
      11-29-2016, 07:32 AM   #3
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Normally replace both the t-stat and water pump at the same time since they are right next to each other and both are prone to failure. Then you should be good for another 50k+ miles.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      11-29-2016, 09:58 AM   #4
Euroboost91
Euroboost91's Avatar
Russian Federation
57
My car had the same issue and it turns out the waterpump failed, most likely the same in your case.
2011 E90 335i LCI 6MT | Bagged |
IG: rrs_simplee90
      11-29-2016, 11:52 AM   #5
TeinBMW
133
Drives: 2011 335xi Msport, Conv, Tech
2011 BMW 335xi  [7.00]
Change out the water pump and thermostat....you can keep driving it but the codes will keep coming up until your car fails. Advice: get them replaced ASAP to avoid further engine damage.
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
      11-29-2016, 06:52 PM   #6
wtobiason
wtobiason's Avatar
Drives: 2018 BMW M4
Has anyone else had this happen and the car had very little power without the CEL coming on?
      11-30-2016, 07:22 PM   #7
OneMoreAlex
OneMoreAlex's Avatar
45
Drives: 2012 e92 335i
Sounds like the car went into low power mode. If you have the JB4 set on 1/3 you won't get the CEL light to come on. Disable autoclear with command 1/4.
Like others have said your water pump is probably on it's way out. I'd get it checked asap. The same thing happened to me and the car left me stranded on the side of the highway waiting 5 hours for a tow truck.
12' 335i
| CP-E CP | MHD | VRSF DP | ALPINA B3 |
      12-01-2016, 08:38 AM   #8
wtobiason
wtobiason's Avatar
Drives: 2018 BMW M4
I do have the JB4 auto clear DME disabled and didn't get a code. I checked the code 1/1 and got 348A. Weird.
It's going in the shop to change the thermostat. My shop recommended waiting for the water pump seeing how I have 62k miles.
      12-01-2016, 08:41 AM   #9
wtobiason
wtobiason's Avatar
Drives: 2018 BMW M4
Did yours come up with the thermostat stuck open code?
      12-03-2016, 05:21 PM   #10
MadToy
64
Drives: '18 340i Xdrive
62k is about the time the water pump fails. Change both, since it's the same amount of labor.
2018 340i F30 Xdrive
      12-04-2016, 05:49 PM   #11
DunklerEngelVNV
Krieger
DunklerEngelVNV's Avatar
Just to add my experience, my water pump went out *shortly* after hitting 60k... Similar symptoms. Agree with doing thermostat at the same time.
      12-09-2016, 11:00 AM   #12
MacE90
MacE90's Avatar
36
Drives: Chevrolegs
2011 335i xdrive  [10.00]
I also am experiencing this code and oil temp never reaches operating temperature in cold weather. I replaced the water pump and thermostat and still have the same problem. Comments?! I am running an aftermarket radiator (CFS) and will be putting the stock unit back, along with a new temperature sensor. Wtf?!
      12-09-2016, 11:49 AM   #13
JETmn
2011 335Xi  [0.00]
If you aren't reaching temp the thermostat is the main control for that. I would double check connections on that. Possibly the thermostat for oil (if you have remote oil cooler)? I wouldn't think that could hold temps down low enough on its own, but maybe in the cold it could.
      12-09-2016, 12:37 PM   #14
MacE90
MacE90's Avatar
36
Drives: Chevrolegs
My money is on the coolant temperature sensor because I found a shadow code for it along with the 348a code (go n55 mhd!!). I'll report back if that fixed it! Sorry for the thread highjack, OP!!
      12-20-2016, 09:10 PM   #15
MacE90
MacE90's Avatar
36
Drives: Chevrolegs
Came across a thread on n54tech about a bt jb4 connect kit being powered by the 12v 50amp fuse (same power source as the jb4) and causing CANbus issues. My bt jb4 connect kit is also powered by the 50 amp fuse. I switched it to a different hot wire in the wire loom and no more 348a code and my cooling system is back to normal function.
