11-27-2016, 05:26 PM | #1 |
7
Rep 42
Drives: F10 m5 2013
Jb4 M5 - Sae Dyno Test On South Korea
yesterday i run dynotest wiy my F10 M5 2013 JB4 SETTING RUN S.A.E MODE NOT STD MODE.... Run result runfile 0,1 : JB4 MAP1 SETTING 615~626HP / 83~84TORQUE runfile 2 : JB4 MAP4 (OEM STOCK SETTING ) 515HP / 72TORQUE runfile 3 : JB4 MAP2 SETTING 547HP / 75TORQUE I think jb4 map2 program is something is trouble on my m5 sometimes i run map2 is over 6000rpm~ when its stop here 1seconds and run overflow.... it i think it's transmission is slip or A.F.R IS some need it..or fuel cut ? http://blog.naver.com/rpm8300/220871230699 here is my blog on south korea have dyno video and more my data
11-27-2016, 05:42 PM | #2 | |
446
Rep 1,300
I had same problem. Also your map 1 was almost identical to mine. Car is healthy! |
11-27-2016, 06:10 PM | #3 | |
7
Rep 42
Drives: F10 m5 2013
sir how to change map2 run flash ? are you resolve this problem?
11-27-2016, 08:03 PM | #4 | ||
446
Rep 1,300
Once you do that you should see considerable gains over the map 1. |
11-28-2016, 02:00 AM | #5 | |
7
Rep 42
Drives: F10 m5 2013
so you mean ecu resetting mean ? from bmw service center ? or jb4 cand reflash it ?
11-28-2016, 08:09 AM | #6 | ||
446
Rep 1,300
You need an aftermarket tune from a reputable company. |
06-08-2017, 12:11 AM | #7 |
17
Rep 63
