How does everyone's DCT feel like?
11-27-2016, 05:56 AM | #1 |
Eric_Y
103
Rep 456
Drives: 2016 340i, 2010 E92 M3
Hi guys,
I noticed that the car has a bit hesitation when starting to roll off red light. Basically when I release the brake pedal car almost won't move and then I foot on gas pedal, at the very first second it behaves as if it is hesitating to go or not. This feeling is completely different and noticeable from my previous E90 6AT, F30 8AT. For these cars if I release brake pedal it will move smoothly by itself. My DCT car also moves but just feel power is not delivered to wheels. I don't know if this is the feature of DCT? Also in D gear, I have to almost open more than 50% throttle to let it downshift. In S gear it's more active in downshifting. But D gear is terrible, car just won't shift unless I open a wide throttle or kicked down. Anyway to reset DCT? Thanks heaps |
11-27-2016, 06:39 AM | #3 |
Eric_Y
103
Rep 456
Sorry forgot to mention car's condition. 2012 E92 335 51000km on the clock. No transmission service done yet.
11-27-2016, 07:00 PM | #7 |
34
Rep 166
I have just done transmission job at 39000 KM, from the looks of the oil filter I could say that it was about time.
Try doing that and see what happens |
11-27-2016, 11:38 PM | #8 |
555
Rep 922
You need the DCT software and ECU update, certain older versions had some poor responsiveness. Just got to a dealer or specialist and ask them to update to the latest versions.
Mine was the same when I first got it, certain situations would be very unresponsive, as if it's paused for a second to think about which way to shift. After updating it's perfect, instantly kicks into gear when it needs to. Plain old D mode is perfect for regular driving since then. Or just go straight to getting MHD flasher, it updates ECU as part of its setup process anyway(not transmission, but you might only need ECU update, in my case it was only the ECU update it needed). 51 000 km is very early for a DCT trans service, I'd leave it until 100 000km. It's not a regular auto, you won't see a different from such an early fluid change. Although do check it isn't leaking transmission fluid, or get the shop to check it's ok, that's a fairly common issue. Last edited by maddmatth; 11-27-2016 at 11:44 PM.. |
11-28-2016, 12:55 AM | #9 | |
Eric_Y
103
Rep 456
Overall my feeling is, D=smoothest but slowest acceleration, S=punch & sensitive; D+sport mode = less smoother than D(more downshift) but more responsive than D (one gear lower); S+Sport mode = restlessness. |
11-28-2016, 12:56 AM | #10 |
Eric_Y
103
Rep 456
11-28-2016, 12:57 AM | #11 | |
Eric_Y
103
Rep 456
Did you update ECU or TCU? I am about to go for MHD N55, but can I address TCU issue by only remapping ECU? |
11-28-2016, 03:18 AM | #12 | |
555
Rep 922
But if your TCU isn't up-to-date, it would be good to take care of that too. Also another minor thing to note, sport mode (the sport button) does influence shifting too. Just hitting that, without moving the shifter over, does make the car use slightly more aggressive shift points, good for back roads where the full on "race track shifting" of DS mode is too much. Personally I never use DS, it's either D or I go to manual sport mode. |
11-28-2016, 01:26 PM | #13 |
37
Rep 134
There really needs to be a commercially available TCU flash for the DCT, that would open up a lot of possibilities I think. I think the guys doing xHP will be on top of this for the DCT crowd.
11-28-2016, 06:28 PM | #14 | |
Eric_Y
103
Rep 456
11-28-2016, 06:29 PM | #15 |
Eric_Y
103
Rep 456
11-29-2016, 08:27 PM | #16 |
139
Rep 227
Just to add a little bit here, every M car that I've driven with the DCT doesn't move until you hit the gas. You can let off the brake at a stoplight and it won't move until you gas it. I haven't driven many of the 135/335 DCT but I remember that some creeped forward, some stood still.
11-29-2016, 08:44 PM | #17 | |
541
Rep 3,131
Drives: 2011 335i e92 DCT
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
11-30-2016, 12:36 AM | #18 | |
555
Rep 922
Not sure why BMW does it this way, IMO the forward creep that autos do is not a good thing so I wouldn't emulate it on a transmission that doesn't do this naturally. It does make crawling in traffic a tiny bit more convenient though, you don't need to move your foot sideways every time the traffic crawls a bit, so it makes some sense. |
11-30-2016, 05:21 PM | #19 |
139
Rep 227
The traffic bit makes sense, I can surely see it being more convenient that way. I was always a little confused as to why the same style transmission would perform differently between M and non-M. Mainly because the only cars with the DCT (at least over here in the states) are the 135is/335is variants that are supposed to be performance models anyways. But I'm sure they still want to separate them from the M models a little more.
