Increased fule consumption. What to log for?
11-24-2016, 11:49 AM | #1 |
10
Rep 50
Hey guys. I have observed lately an increase in fuel consumption. It is something like 15 20% more than it used to be.
I have recently changed the vacuum solenoids and AT fluid. Sparks are 30.000 km old and no misfires. What should I log for to see if it s burning more fuel than normally. I am running MHD Stage 1 FMIC so there are no codes on O2 sensors as far as I know...how should I log for? Stft? Ltft? AFR? |
11-24-2016, 12:01 PM | #2 |
94
Rep 233
Weigh your right foot, it has likely gotten heavier.
Also, idk if leaky injectors can cause noticeable increases in fuel consumption, but you can sometimes see evidence for leaky injectors by watching the AFRs after letting off the throttle. If it were that bad, though, you'd have misfires and rough idle |
11-25-2016, 06:07 PM | #4 |
122
Rep 397
11-27-2016, 09:02 PM | #6 |
ahat
1036
Rep 2,592
AFR is lambda.
Plot throttle opening at steady state speed and AFR, with STFT. Should be flat lines. If not does it also vary at cold start? If cold start is fine but variation comes into play after operating temp change front O2 sensors first. Especially if mileage is over 100K. If the same problem also exists at cold start you probably have other issues. Missfires most likely. Its unlikely lean condition from a vacuum leak would significantly affect fuel consumption at steady state speed.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 11-27-2016 at 09:09 PM.. |
