Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > crankshaft pulley
      11-22-2016, 03:42 PM   #1
Nipplebro
35
Drives: 2012 335 m sport n55
crankshaft pulley
does anyone make a crankshaft pulley without that rubber shit? like a solid steel one? mine is wobbling
      11-23-2016, 02:37 PM   #2
kimoboy
47
Drives: E90 335i
Would be nice to have light pulley for more power
      11-23-2016, 06:37 PM   #3
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Really? This isn't a NA honda. The reason the rubber is there is for harmonic balancing, but we should need too much on an I6 since it is inherently balanced.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      11-23-2016, 06:42 PM   #4
Manberg
Manberg's Avatar
Drives: 2011 e90 335i
Yeah, don't fuck with your engine harmonics. Its a lot more effective on things than you would think.
M-Sport, 6MT, PPK, JB4 ISO + Rev.3, VRSF 7'' FMIC, VRSF Catless DP, BMS Charge Pipe, MFactory LSD, Öhlins R&T, M3 Control Arms, Rogue 6MT Bushings, Remus Exhaust, Duke Dynamics CF Diffuser, Cyba Scoops, VMR VB3 19s, BMS Clucth Stop
      11-23-2016, 11:03 PM   #5
Nipplebro
35
do you think I can drive it like that? will it explode and destroy my motor
      11-24-2016, 12:17 AM   #6
Manberg
Manberg's Avatar
Mine has a slight wobble to it too, but im not super concerned.
      11-24-2016, 11:50 AM   #7
Nipplebro
35
Dude I really want to drive my car but I am scared the pulley is going to explode or some shit
      11-24-2016, 05:30 PM   #8
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
The OEM is Corteco I think... I've only been able to find genuine BMW, but I'm sure someone from OEMBimmerParts will be able to help track it down.
The balancer is really easy to change compared to like every other car. Just a series of bolts and it pulls right off. No struggling with a big center bolt or anything.
      11-26-2016, 12:30 PM   #9
Cory S
Cory S's Avatar
Drives: 2011 335i-X
It's just a Harmonic damper, not a balancer. The N54/55's, as well as most of BMW's engines are internally balanced.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
      11-26-2016, 03:04 PM   #10
JETmn
2011 335Xi  [0.00]
Harmonic balancer and damper are interchangeable. An inline 6 is nearly perfectly balanced in the primary and secondary phases so it doesn't need external mechanical balancing.
      11-26-2016, 04:50 PM   #11
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Jet.... What? LOL... Was that a correction or were you just agreeing?
But yeah, a balancer is also and damper in most cases, but a dedicated damper is not technically a balancer.
Coffee Brandy?
      11-26-2016, 08:57 PM   #12
Welcome to NBA Jam
Is it the shoes!?
3884
It's interchangeably used in the same way that people say "Freon" when they really mean "R-134A." It's not correct but...eh we get the picture
      11-27-2016, 10:45 AM   #13
JETmn
2011 335Xi  [0.00]
Coffee Brandy?
Are you saying a harmonic balancer actually balances the crankshaft mechanically? I think you need to do some research. It only balances the harmonics, not physical balancing. That is build in to the crank shaft and why engines with improper inherent balancing have balance shafts.
http://www.fluidampr.com/what/what-i...aft-damper-52/
      11-27-2016, 10:50 AM   #14
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Actually, a harmonic balancer usually around 25-60oz is mated with a matching flywheel, balances the crankshaft assembly, and has a fluid or rubber harmonic absorbing ring.
A balancer does not balance harmonics itself.
      11-28-2016, 08:02 AM   #15
JETmn
2011 335Xi  [0.00]
I think you are getting mechanical and harmonic balancing mixed up. A harmonic balancer does balance harmonics, that is its job. It does not have anything to do with mechanical balance though (might be an oddball case here or there, but not on most engines).
      11-28-2016, 09:40 PM   #16
shirtpants_
shirtpants_'s Avatar
94
Drives: 11 335i
Just took a look at mine tonight, and it's wobbling as well. Could be the source of my strange engine bay noises. There goes 500 bucks on a new one.
I know Justpete was working with ATI on a superdamper. Dunno if it ever came to fruition. I'll ask him and see.
      11-28-2016, 09:42 PM   #17
Nipplebro
35
thanks man let me know please
      11-28-2016, 10:02 PM   #18
shirtpants_
94
Drives: 11 335i
Pete didn't get back to me yet, but i found this
https://store.vacmotorsports.com/vac...n54-p3758.aspx
I contacted VAC to see i this will work with the N55. Will update you guys.
The big advantage of this is for people with LWFW and/or solid engine mounts
      11-28-2016, 10:30 PM   #19
Nipplebro
35
nice! hopefully it will fit the n55. my mechanic said I'm just going to screw it up again running higher boost, is there any truth to that?
      11-28-2016, 10:37 PM   #20
shirtpants_
94
Drives: 11 335i
Here's what justpete said:
"Got it, installed, all vibration is gone. They're in stock for both N52 and N54 at VAC Motorsports. Pricey sumbitches though. I've followed some of the N55 discussions but I've no clue what the difference is between an N54 and N55 damper."
So this is the link to the damper he helped develop, or at least tested. https://store.vacmotorsports.com/vac...n54-p3758.aspx
I checked the part #'s for the crank pulley for the N55, N54, and N52, and they are all 3 different numbers.
The numbers are different between them on both RealOem, and ECStuning
We will see what VAC has to say about it fitting the N55
      11-28-2016, 10:40 PM   #21
Nipplebro
35
Okay sounds promising, just don't want to buy one and it takes a shit again. I'd rather pay more for something more reliable
      11-29-2016, 07:38 AM   #22
JETmn
2011 335Xi  [0.00]
You do put more stress on it the more power you run. It is still trying to turn all of those accessories, but at a much greater acceleration rate. I think an aftermarket one would be great! Then we shouldn't have to worry about it again.
