Very interesting Earthquake sub info
04-08-2008, 05:10 PM | #1 |
102
Rep 1,035
I called Earthquake today to ask them about the frame for the 8" SWS. They passed me directly to the engineers because the tech support guy was out. I talked to a really cool guy there who knew the sub inside and out and was part of the design team.
My question was why do the pictures on the website show a round subwoofer when the sub actually has an oval/square shape. All the 8" are this shape. He said that they actually used that basket design because they were working with BMW. I told him that's exactly why I called. He said the 8" will drop right into the BMW underseat box and they actually designed that box, which he said vents to the frame, for Harmon Kardon. The OEM subwoofer is just a lesser version of the SWS. If you look at the SWS box recommendations, the slot loaded box is very similar to the BMW sub enclosures. So I asked him about the SWS vs the OEM sub. He said the SWS uses the more advanced design and is better in every way, better than even the premium sub. He mentioned that if you are installing the sub, do not press on the aluminum cap as that actually functions as the heatsink. He was very talkative and candid and was really happy to be talking to an end user. He told me that I might want to wait for the new 8" SWS that will come in a 2 ohm voicecoil. It is designed to drop into the box and be more efficient than the 4 ohm version but it's meant to work with the factory amp. So since I'm using an aftermarket amp to drive the sub, I'll just go with the currently available 4 ohm as there will be no benefit for me. Anyone looking to use the OEM amp but just upgrade the subs should wait for this new 2 ohm version as since the impedance is half, the power it will receive is nearly double from the OEM amp. They just finished the design on it and shipped a sample to Germany today, it's coming out soon. So there it is in a nutshell. Kudos to everyone using the SWS 8s. |
04-08-2008, 05:30 PM | #3 |
102
Rep 1,035
That I am not sure of. Because the base system is powered by the head unit which puts out a measly 15 watts at 4 ohm. I don't know what the impedance of the OEM sub is but if it's more than 2 ohm, you could cause the headunit to overheat as the new SWS subs will be 2 ohm. Hifi and Logic 7 will see a benefit. With the base system what I'd probably do is at least add an amplifier and go with the 4 ohm subs.
04-08-2008, 05:44 PM | #4 |
You live by the sword...
216
Rep 8,244
^^^ I see...thanks again. I didn't know that about the head unit in the E90. In the E46, both base and HK systems used an amp in the trunk (at least US versions...european versions were powered by head unit).
04-08-2008, 06:28 PM | #5 | |
2307
Rep 13,011
The HiFi underseat subs are in fact 2 ohms, in the Top HiFi they are 4 ohms. So this new SWS-8 at 2 ohms is the perfect replacement for the base HiFi OEM system in the USA. |
04-08-2008, 06:36 PM | #6 | |
24
Rep 481
04-08-2008, 06:54 PM | #7 | |
2307
Rep 13,011
Your Logic7 uses OEM 4 ohms underseat subs, so the current SWS-8 (4 ohms) is the correct replacement to match the OEM amp output. |
04-08-2008, 06:59 PM | #8 | |
102
Rep 1,035
Sorry for the confusion, I thought base meant that most basic system which was not amp powered according to that PDF. I don't know all the differences between the Euro and US specs. Thanks for the correction. |
04-08-2008, 08:26 PM | #9 |
12
Rep 566
Has anyone actually tried replacing the Logic7 sub with the SWS-8 without adding an amp? How does it sound? I'm interested in upgrading the sub, but don't want to mess with adding an additional amp.
04-09-2008, 05:17 AM | #10 |
Lance Corporal
19
Rep 128
The only trouble I see with the Earthquake is that it models very poorly in a small sealed enclosure. The small sealed under seat box handicaps its low-end output and causes a huge bump around 80hz and then it drops severely after around 150hz or so. This is less than ideal if the subwoofers are run from 30-500hz like some of the factory literature I've seen says.
The Earthquake really wants to be run infinite baffle as in a door or rear deck. They'd be incredible subs for a rear deck installation - perfectly flat response to almost 30 Hz. On the other hand, there really aren't any other drop in solutions short of the Aurasound shallow 8" which is a mid-bass and not a subwoofer. The Pioneers don't drop-in and all of the shallow Morels I've seen are too big. You could probably run the Earthquakes and drop about 4-6 dB from 80hz on the EQ, raise 200Hz, and then turn the bass up with should bring up the 50hz range thats naturally rolled off. I think a lot of people who hear them will hear that huge 80hz bump and mistake that for quality low-bass. Here's the gain plot, green is in a 5.0L sealed enclosure and yellow is IB: http://ims.hspn.com/pic.php?u=3134yPt&i=4528 |
04-09-2008, 06:41 AM | #11 | |
2307
Rep 13,011
I tried that 5L (.1736 cu.ft., SWS-8 recommended enclosure size in the manual) sealed enclosure and it is simply not the right size for this sub. The bass was just not there, considering that it was supposed to provide "deep bass from the shollowest space" using that specific enclosure size. So far, the best performance has been using a 14 - 17L (.5 - .6 cu.ft.) sealed enclosure. Really nice sub bass down to 30Hz with up to 200W RMS (maximum is 150W RMS). Because the OEM sub enclosure is actually not sealed -it is ported into the door sills- the SWS-8 response should be similar to a much bigger sealed enclosure than .17 with the right amount of power. However, I don't think that any of the OEM amps, except perhaps the Dirac DSP (825W max) amp, have the power necessary to really get these subs going in any enclosure type. At least they need 100W RMS per to move the way they are supposed to move... |
04-09-2008, 09:18 AM | #12 | |
216
Rep 8,244
I'll definitely be in the market for the new 2 ohm in that case (don't want to spend too much money on amps/subs/speakers/wiring/dynamat/etc/etc....been there/done that too many times). |
04-09-2008, 12:30 PM | #13 |
102
Rep 1,035
The box under the seat is not sealed though the FR I'm sure will not be a flat line. However, replacing the OEM sub should yield improvement and if you had a good EQ on the sub, it can sound pretty good. As far as power handling on the subs, I've found that their recommended power limit is a very good guideline to follow. The 10" I ran in my NSX made some mechanical noise when being pushed just barely over recommended power rating.
04-09-2008, 01:39 PM | #17 |
18
Rep 490
04-09-2008, 03:39 PM | #18 |
7
Rep 92
Drives: 2015 M3
I've got two SWS8's waiting to be installed. I thought that I would seal the under seat enclosure to get better (deeper) bass. I plan on a Soundstream Rubicon 1000-2 for power 2X200watts @ 4ohms. As I read the above posts, I now understand that I should, in fact, leave the ported (factory) configuration to get the best bass. Am I correct, or have I missed the point? Thanks.
04-09-2008, 03:44 PM | #19 | |
102
Rep 1,035
I picked up 2 SWS 8's from my distributor today. Curious, what are you guys paying for these? I get them for $79 each, but that's from a distributor, not an audio shop. I think they have 7 more. It also looks like there will be a small gap when the sub drops in where the plug is. When I put mine in, I'll figure a way to plug it up. |
04-09-2008, 03:47 PM | #20 | |
102
Rep 1,035
04-09-2008, 03:53 PM | #21 | |
216
Rep 8,244
Don't know where i'll get it from yet...i'll most likely get it from a shop by my work since they'll do the install as well (does it involve removing the seat by any chance?) If not, I suppose I can install it myself (haven't looked under there yet). |
04-09-2008, 04:11 PM | #22 | |
102
Rep 1,035
