BMW X3 Forum
BMW X3 Forum
      11-21-2016, 07:05 PM   #1
PAT3L
7
Drives: 2008 BMW 323i E90 4 Door Sedan
2013 BMW X3 Engine Light...Need Help!
I have a 2013 BMW X3 twin-turbo, I've bought it second hand only with 40,000km on the vehicle. After a couple of weeks of purchase I noticed that the oil temperature gauge wouldn't go up at all, sometimes it did but majority of the time it did not.. I also noticed that the car had a lot of hesitation when accelerating, the RPM wouldn't go over 2500 and wouldn't let me exceed anything beyond 100km/hour while other times theres no hesitation whatsoever. Just recently since it started to snow I noticed that the heat wasn't as warm as it should be and that too was lacking... Has anyone faced this issue and was able to fix it? Its out of warranty sadly..
Appreciate the help in advance!
      11-21-2016, 08:03 PM   #2
02420X3
63
Drives: 2011 X3 35i
28i or 35i? If the latter, the thermostat module could be the problem. If it is, consider having the water pump replaced at the same time.
      11-21-2016, 09:39 PM   #3
Alfisti
6503
Drives: 2008 Saab 9-3 Combi
Water pump at 40,000KM (25,000 miles)? Yipes.
      11-22-2016, 06:03 AM   #4
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
it seems like its thermostat, was the fan loud?
      11-23-2016, 10:24 AM   #5
PAT3L
7
Yeah its the 35i, from replies on the thread it seems that is the most plausible, appreciate the help!
      11-23-2016, 10:25 AM   #6
PAT3L
7
Yeah fans quite loud :/
      11-23-2016, 10:30 AM   #7
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
so it must be thermostat module needs to be replaced.
it happen to me twice in 1 week with my 2015 x3.
loss of power and fan was loud. Temp guage needle was stuck in same position.
PAT3L6.50
      11-28-2016, 07:44 AM   #8
PAT3L
7
Did you happen to get it fixed at a BMW dealer? Since mines still in warranty i'm thinking of going in and fixing it. I had called them they said it was $175 + taxes for diagnostics then they'll see if the issue is covered under warranty, so I was wondering is the thermostat covered under warranty, would you happen to know?
      11-28-2016, 07:51 AM   #9
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
yes it was cover under warranty
PAT3L6.50
      12-06-2016, 09:53 AM   #10
PAT3L
7
Quick update, just got the BMW X3 serviced at the dealership, they replaced the thermostat, did a transmission oil change, replaced the heat exchanger and toped up anti-freeze, this was all covered under warranty. I appreciate all the help!
nyalpine907433.00
      12-06-2016, 10:29 AM   #11
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
Tags
bmw x3, engine light, hesitation, no heat
xbimmers
