Low heat in the coupe
11-21-2016, 02:53 PM | #1 |
7
Rep 63
Hi.
I have a problem withe the heat from the fan, itīs not nearly hot enoug. When the fan speed is set to 1 the air temp is about 20c or 68f if i increase te speed the air gets colder and colder. Read that it could be the thermostat. I check the water temperature, when drivin it was about 97c or 206f, at idel it went up to about 108c or 226f. Could it still be the thermostat? if not any ideas what could be the problem ? Best regards Christian |
11-22-2016, 05:03 AM | #4 |
7
Rep 63
Thank you irishace, will start with the stat.
08njstep i have tried that, when on blue it wil be cooler, but when on red it wouldn't be warm enough. Thank you for your input |
11-22-2016, 05:22 PM | #5 |
122
Rep 397
Could also be the water pump going out, however it would only blow cool/cold for a few minutes before you overheat and go into limp mode. This happened to me last winter
Tags |
cold air, fan, heat, thermostat |
