Replacement mounting hardware for FMIC?
11-21-2016, 09:36 AM | #1 |
25
Rep 74
Drives: 2008 335i Coupe 6-speed
Just got my 5" stepped VRSF intercooler and the OEM screws aren't long enough to get enough threads to keep it secure. I know a few people mentioned they went to Lowes to get different mounting hardware, can anyone point me in the right direction? I never got any type of mounting hardware with my FMIC in the package. I did get the silicone hoses and t-bar worm gears, but right now, I don't feel like my FMIC is secure enough.
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
11-21-2016, 02:26 PM | #3 |
25
Rep 74
Nope. I got:
* Intercooler itself * 2 silicone hoses * 4 t-bar clamps That's it. I think I found the mounting hardware on Lowes' website: Hillman Group .25" x 2.25" Zinc Plated Hanger Bolts
11-21-2016, 08:06 PM | #6 |
2095
Rep 43,350
Unfortunately the hex screw in the hands of a novice will result in the plastic striping if too much force is applied. It's the reason we switched to a regular philips head.
Chris@VargasTurboTech1933.00 |
11-21-2016, 09:39 PM | #7 |
530
Rep 2,083
Take the stock screws to your local hardware store and just get the same thing that's slightly longer. Home Depot might have them too if you don't have a real hardware store.
2013 135is DCT Carbon Black Metallic |
Turbod395.50 |
11-22-2016, 09:38 AM | #8 | |
25
Rep 74
That's my plan. I found hanger bolts and was planning on putting a couple of small bushings in between if I couldn't find the longer ones. I'm afraid it'll fall. But, everyone who already has it installed probably hasn't had that happen.
11-22-2016, 10:29 AM | #10 |
Guest
Rep n/a
Drives:
Use hanger bolts; you can get them on Amazon. Length, diameter, etc. have been discussed in the past if you feel like searching for it.
11-22-2016, 10:40 AM | #11 |
25
Rep 74
No worries Tiago. I'll run to the hardware store and pick up some bolts. Thank you for the gesture though. I'm really happy with the quality of it.
I thought about those, too. I can get those at my local hardware store. Get hanger bolts, a couple of rubber bushings, two nuts to screw it into the housing, and then a washer and nut to secure the FMIC, yes?
11-22-2016, 10:42 AM | #12 |
951
Rep 2,669
Drives: e92 + f15
I'd upgrade to stainless steel if you're making the trip anyways. I ran to Lowes, matched the screws there.
11-22-2016, 10:46 AM | #13 | |
Guest
Rep n/a
Drives:
As mentioned, going with stainless hardware is probably a worthy upgrade here. |
11-23-2016, 07:55 AM | #14 | ||
25
Rep 74
Lowes was completely out of stock of the SS hanger bolts, else I would have bought those. No stores nearby had them, and the zinc ones look like pure trash.
11-23-2016, 08:31 AM | #15 |
Guest
Rep n/a
Drives:
