Weird hesitation with no codes
11-16-2016, 05:44 PM | #1 |
25
Rep 74
Drives: 2008 335i Coupe 6-speed
After a 250mi round trip, around 30-50 actual load, the car feels like it loses 10% of power for about half a second. This happens in just about any gear. All I can say is that when i shift into gear and give it a little bit of gas, after about a second, the car feels like it loses power and then goes right back to normal afterwords. WOT is no issue, I do have a boost leak but this is new.
I'm running another log tonight and will post when I get home but this has been happening for the past few days. Monitoring the actual load, boost, and hpfp, they all seem to "drop" when this happens. Haven't changed my tune or anything. Stage 2 MHD 93oct, CP, DP, Muffler Mod, DCI, BOV.
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
11-17-2016, 06:21 PM | #2 |
90
Rep 386
Drives: 08 535xi 11 328xi
If you know you have a boost leak, you should probably start by fixing it. Then see if this problem goes away.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
11-17-2016, 06:25 PM | #3 |
28
Rep 265
I don't mean for this to be obvious or some sort of smart answer....
maybe the boost leak just recently got a little worst? Pipes can shift/move slightly. if a clamp wasn't on straight or loose (or fastened on/too close to a curve), maybe it worked itself loose and caused the leak to be worst?
08 335xi- CP-E DCI's,VRSF 7" FMIC, UR Charge pipe w/ Tial Q BOV, JB4 G5, PE mod, 19" Sonic Tuning SC 7 wheels
11-18-2016, 09:01 AM | #4 |
25
Rep 74
Could it happen even though I'm not in boost? In most cases when driving, I'm not in boost. I'll check this weekend. I've got plans to check over everything including pressure testing, checking vacuum lines, among other things. Just weird that it happens while I had been driving for 100+miles in one day and just cruising.
