11-22-2016, 07:25 PM | #2 |
1418
Rep 2,560
Drives: Rapidly from A to B
All depends what look you are after or whether you have an alternate objective like stuffing more tire into the wheel wells. Lots of factors to consider including tire size, wheel size, suspension, and objective. If on stock suspension and tire size with 0 rub I would shoot for approximately 5 mm off of stock which would bring you to 24 front and 35 rear. You could probably go more aggressive (lower offsets) but these would be a safe starting point. Wider tires and suspension mods will definitely affect where you take it from these starting points.
11-22-2016, 07:36 PM | #3 | |
34
Rep 46
I have h&r springs but I have 2 options for aftermarket wheels. Both are with factory tires 1: 9x19 et 24 front and 10x19 et 40 rear 2: 9,5x19 et 22 front and 10,5x19 et 34 rear Maybe if I go with a kw o mperf suspension the second option would be better but very agressive? |
11-22-2016, 08:58 PM | #4 | |
1418
Rep 2,560
