Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Anyone used this guibo?
      11-16-2016, 01:16 PM   #1
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
Replaced a driveshaft in a 2007 335i E93 yesterday and found the new driveshaft had a different guibo..
Have any of you guys tried it? It works perfectly fine in the car and I assume it's stronger than the rubber ones?
Here's a link to FCP euro:
https://www.fcpeuro.com/products/bmw...12-26117605629
      11-16-2016, 01:25 PM   #2
FCobra94
Guest
n/a
Drives:
I've been running it for 2+ years, no issues.
      11-16-2016, 02:10 PM   #3
klipse
37
Drives: 09 E93 335i
Wonder when they change was made
      11-16-2016, 02:17 PM   #4
FCobra94
Guest
n/a
Drives:
IIRC, they started out as being standard equipment on the 1M. I *think* that may have continued onto the 335is and other vehicles, but not really sure.
      11-16-2016, 02:18 PM   #5
klipse
37
Drives: 09 E93 335i
Interesting. I have an E93 but its an early 2009.
      11-16-2016, 02:24 PM   #6
jjbmuu
4ut0strd4
Drives: 08 AW E92 335i 6 Speed
Yeah this one is considered an upgrade, but my original guibo on my car with 90k miles on it looks to be in great shape. I don't see why it wouldn't last at least 125k before needing a change. Usually the center support bearing rubber goes first though and then you might as well just do the guibo with it..
08 E92 335i Alpine White On Coral Red 6 Speed
BMS DCI+Aquamist METH Kit+MHD+VRSF+AR25 Resonators+HPF IC+AA CP+AA BOV+SSK+KWV1+Mfactory SMFW+550i/335is Clutch+BBS LM Reps+Diff Brace+M Performance Shift Knob+RB PCV+HPF OCC+NGK
Mustang Dyno: 426whp/484wtq on E30/Meth/Stock Inlets+Outlets/Procede Only @ 18psi
Current Estimate: 450/500 on E50 Custom EDC Tuning MHD Flash @ 21psi
      11-16-2016, 02:43 PM   #7
Stucks
Stucks's Avatar
Drives: 2017 F30 340i Xdrive
been using one for over a year. they first started using them on the 2011 335is with the n54s. stronger than the older version, it is an upgrade as some have said in here.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      11-16-2016, 03:25 PM   #8
homemade_f81
312
Drives: 2018 340i, 2020 M2CS
I think these were rolled out to all e9x in 2011 - I have 2011 n55 and it also uses this same guibo
      11-16-2016, 05:37 PM   #9
LQQKOUT
102
Drives: 335XI
Yes. You'll need the new bolts also because they're longer
feuer4275.50
      12-23-2016, 07:44 AM   #10
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
If upgrading from rubber, can you reuse the old bolts or does it require different/longer bolts?
2007 E92 335i MT
      12-23-2016, 04:10 PM   #11
LQQKOUT
102
Drives: 335XI
Old bolts are to short.
      12-24-2016, 09:50 PM   #12
Jklad
Jklad's Avatar
This is the only thread I've seen that's made mention of the metal guibo requiring longer bolts than the rubber version. Would you happen to have the part number? I've spent some time trying to locate them and cannot, and somebody else said that both guibos are the same thickness and use the same bolts. Thanks.
2007 E92 335i MT
      12-26-2016, 07:31 PM   #13
nanceman
nanceman's Avatar
91
Drives: 11 335is 6MT, 15 GTI 6MT
I called and checked on this and on realOEM and this is incorrect. All 335is use the same bolts PN 26117527475, I have an early (5/10) build and when I did my Quaife and Turner Aluminum / delrin RSFB's I did this as well. Transmission output shaft, drive shaft, and fasteners are the exact same. Only the Guibo changed.
Where were you told this?
Jklad421.00
      12-26-2016, 07:40 PM   #14
nanceman
nanceman's Avatar
91
See below, Guibo PN change at 10/10 only. No other changes, including BOM#3 hex bolt. Change was on all 335is from 10/10 on, screenshot below was for a 2012 build 335is for reference.
Appreciate 2
Jklad421.00
      12-26-2016, 07:55 PM   #15
nanceman
nanceman's Avatar
91
Note, there are two different questions here:
1. The hex bolts to use are the same PN for both Guibo's
2. The hex bolts cannot be reused, however. These are ZNS torque to yield fasteners that stretch to achieve ideal axial load. They must be replaced with new fasteners, just the same PN.
Appreciate 2
Jklad421.00
      12-28-2016, 08:50 AM   #16
Island Road
167
Drives: 335i
2008 335i  [10.00]
Been running this part for little under a year now, also used the same bolts so no they don't need to be changed they work just fine.
08 AW 6MT | MHD | Wavetrac LSD 3.46 | AE Quad | VRSF DP'S | VRSF 7" IC | DD Hood / Diffuser| Mtech Front / Rear| BMW Performance Splitters / Spoiler | Wheels 18lb 18x9 SQ | Hexon RR550 | TFT Inlets
Appreciate 2
Jklad421.00
