BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Steering wheel off-need input!
      02-17-2006, 04:37 PM   #1
Silv3
Drives: BMW
My steering wheel is off to left. It is very minor, but it bugs me. The dealer did an alignment. They said it was slightly off and now it is within specs. The steering wheel is still off to the left.
The car rides good, and i know all about the crowns in the road and so on. Went for test drive with the SA, he first said it was slighlty off, but not enough to make changes. Then he said, overall the car is within specs and all is fine. Anyone have this issue? Any input?
Thanks.
      02-17-2006, 09:36 PM   #2
tctic
38
Drives: BMW E90
I notice this with mine too. I have to adjust it to the left a bit sometimes. Some of the causes of this might be the curvature of the road and the bumps along. Also check tire pressure. I first thought the run flats won't make a big impact to this since it has stiff sidewalls but I was wrong. I corrected the tire pressure and the problem was much improved.
      02-17-2006, 09:43 PM   #3
Carl
Drives: e91 red loaded
My SA told me he has over ten cars that need to be adjusted. He said they have been coming misaligned from the factory. Said it just started happening in the last 30 days
      02-26-2006, 10:19 AM   #4
lumbergh
lumbergh's Avatar
Drives: BMW 325i
Mine was off center to the left from the factory, it was pretty noticable. They pulled it off and reset it.
I am glad because that is my biggest pet peave with a car.
      03-18-2006, 08:14 PM   #5
romain
Good MAN....
romain's Avatar
21
Drives: AW-325i e90
Mine is off too
      03-22-2006, 02:10 PM   #6
cobradac
cobradac's Avatar
20
Drives: '05 645Ci Coupe
2005 645Ci  [0.00]
SIB on Steering Wheel Offset (Alignment)
Here is new Service Bulletin on Alignment
SI B32 05 06
Steering and Wheel Alignment March 2006
Technical Service
SUBJECT
MODEL
E90 (3 Series) and E91 (3 Series Sports Wagon) equipped with xDrive and produced up to 2/06.
SITUATION
Customer may complain of a slight steering wheel offset (about 5 degrees) when driving straight ahead.
CAUSE
The steering gear was not properly positioned to the front axle carrier.
CORRECTION
In case of a customer complaint, perform a wheel alignment to center the steering wheel.
The steering gear brackets have been improved in 2/06 to have a better position in relation to the front axle carrier.
PROCEDURE
Torque the bolts connecting the steering gear to the front axle carrier to 56 Nm.
Perform a wheel alignment and center the steering wheel per Repair Instructions RA 32 00 150 (with load) or RA 32 00 155 (without load).
Perform steering angle sensor adjustment/calibration per Repair Instructions RA 61 31 996.
WARRANTY INFORMATION
For information only
