11-08-2016, 02:40 PM | #1 |
2349
Rep 2,828
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
DYN-O-MITE Time !
So I woke up this pass Saturday morning decided to drive the m2 stop by Costco gas station filled up the tank and decided to visit European Auto Source to do a basic dyno. (Dynojet)
Here are the results on 91 octane (shitty gas from Costco ) we did three runs : With the same result: 322-329 and the last three runs we decided to add 1 gallon of E85 octane on 3/4 on 91oct Result: 340-352 Waiting list : Software Downpipes
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
11-08-2016, 03:02 PM | #2 | |
80
Rep 269
I guess that is not bad for 91 octane. My car did 350 whp + 417 ft-lbs on 93 octane on a dynojet as well...
No Boost4019.00 |
11-08-2016, 03:44 PM | #3 |
2349
Rep 2,828
I need the ManaJuana for more hp ..Lol
11-08-2016, 05:17 PM | #5 | |
4155
Rep 3,057
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Those base numbers look good OP.. Has anyone tried any Sunoco 100 octane?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
FSociety3810.00 |
11-08-2016, 09:27 PM | #7 |
IG @bmwF9xG80
3810
Rep 7,594
Costco is by far my fav gas for the past solid year.
Its the most consistent station to station gas brand I've used in my X3 and X4 M40i. Heck, those are solid results for 91 and wow 439wtq with just 1 gallon of e85
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-05-2017, 05:36 PM | #9 |
IG @bmwF9xG80
3810
Rep 7,594
They run lean from factory but an extra gallon of E85 won't make it much leaner that one should worry about.
02-05-2017, 06:47 PM | #10 |
538
Rep 752
02-05-2017, 11:09 PM | #11 | |
624
Rep 796
The m2 actually runs a bit rich compared to other n55's. Normal is 12:5:1, the m2's stock tune dips into the 11's. |
02-06-2017, 06:41 AM | #12 |
1120
Rep 1,643
Most DI motors can be tuned safely to run mid 12's for AFR.
ashburyn54623.50 |
02-06-2017, 08:29 AM | #13 |
538
Rep 752
Thanks! Did you have any tunes or mods when you took that datalog?
02-06-2017, 10:41 AM | #14 | |
624
Rep 796
Honestly I'm glad the m2 has thicker AFR's. A lot of times people running this setup on the m235i have scary lean AFR's considering the torque curve hits so hard, so quickly. Does anyone on here have experience with the ECU psi going above the DME boost target? |
02-06-2017, 10:43 AM | #15 |
624
Rep 796
02-06-2017, 11:27 AM | #16 | |
538
Rep 752
Thanks! |
02-06-2017, 11:29 AM | #17 | ||
624
Rep 796
The ECU psi could be causing throttle closures. |
02-06-2017, 11:44 AM | #18 | |
538
Rep 752
How much higher PSI are you seeing? What's stock boost set at? |
02-06-2017, 12:35 PM | #19 | ||
624
Rep 796
02-06-2017, 12:41 PM | #20 | |
538
Rep 752
So under throttle what does the car use if it's not using the MAF? |
02-06-2017, 12:58 PM | #21 | ||
624
Rep 796
Actually the DME BT and ECU psi aren't as far off as I thought. JB4 is probably just learning. The factory DME targets up to 14-15.5psi I believe. Hangs in the 11-12 range most of the time |
02-06-2017, 01:09 PM | #22 | |
538
Rep 752
Also, how's the induction sound with the burger unit? Thanks! |
