MOST Loop
11-08-2016, 08:27 AM | #2 |
529
Rep 2,503
Looks good to me. Just double check it's correct for what you want to bypass.
Some MOST connectors used by BMW have a 4pin connector built in for modules like cd changer and amp. TCU doesn't and is just normal 2 wire fibre optic light in and out connector. |
11-08-2016, 09:14 AM | #3 |
13
Rep 86
It is a 2 pin. I take it that the green wire and the wire in the black shield are FO, what do the other two wires provide for? And also can I remove the two FO cables from its location at the back seat?
11-08-2016, 07:22 PM | #4 | |
Where'd my VTEC go?
481
Rep 6,067
If you remove the proper cables from the fiber optic hub then you no longer need the loop. The loop is the easy method so you don't have to mess with the hub.
11-09-2016, 05:10 AM | #5 |
13
Rep 86
Thanks. It will let me take that money and use it for cables. Any chance you might have the part numbers for GPS and Sat cables (or suggested aftermarket) from the aerial to the HU. I will be taking down the head liner to re-route cables
11-09-2016, 11:42 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
You can dig around realoem.com but it's probably integrated into the vehicle harness and not sold separately.
Any FAKRA cable should work, but be aware there are different orientation for the connectors and they are color coded. I believe a FAKRA "Z" connector is universal.
11-09-2016, 06:31 PM | #7 | |
13
Rep 86
When you say orientation do you me straight connectors, 45 degree connectors? |
11-09-2016, 09:04 PM | #8 | |
Where'd my VTEC go?
481
Rep 6,067
11-10-2016, 05:20 AM | #9 | |
13
Rep 86
11-10-2016, 09:01 PM | #10 | ||
Enthusiast
167
Rep 1,622
11-10-2016, 10:47 PM | #11 |
Where'd my VTEC go?
481
Rep 6,067
Yes, they are identical. I don't about the OHM rating or anything like that. I bought some generic 20 ft long FAKRA cable from ebay to extend the SDARS antenna from my trunk to NBT, and it works fine.
11-11-2016, 09:21 AM | #12 |
13
Rep 86
Yes I have MULF2 and TCU along with SDARS. Do you have an aftermarket source you can provide for cables, unions and connectors!!. I figure that as long as I have the FO hub exposed to remove what I don't need: taking down the head liner to0 run two solid lines direct to the HU is not that much more aggravation, I think the less connections the fewer issues of failure.
11-11-2016, 09:25 AM | #13 | |
13
Rep 86
My research shows that the cable used for GPS is RG-174/U 50 ohm rated Last edited by xyzed; 11-12-2016 at 11:18 AM.. |
