BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis G30 wheel bolt pattern?
      11-03-2016, 04:01 PM   #1
ted99
Drives: former i3>330e, 528i>X5>530e
Now that the German order sheet is out, does anyone know what the wheel bolt circle is for the G30? For the F10, It's 5-120mm, 72.6 hub and 35mm offset. I heard some speculation that BMW was going to 5-112mm for it's next cars. Anyone know what has happened? I'm hoping that I will be able to use my spare set of F10 wheels.
      11-03-2016, 06:38 PM   #2
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
G10? Do you meant he new 7 series G11/G12? If so, it has the new 5x112 bolt pattern.
The new X1 and the 2 series Active Tourer + Gran Tourer also have the new 5x112 bolt pattern.
I've seen the G30 in real life and the bolt pattern looked smaller, so I'm 99% sure it will have the 5x112 bolt pattern.
      11-04-2016, 02:46 AM   #3
ted99
Oops
Wrote G10 when I should have written F10. Corrected now. Thanks for your observation.
      11-06-2016, 09:31 AM   #4
RMcoolX
9
Drives: 2014 528i
So will my current F10 aftermarket wheels bolt right on to a G30?
2014 X5 35i (w/N55 Stage 1 Tuner)
2012 C6 Vette (w/Supercharger)
      11-06-2016, 11:15 AM   #5
ted99
Remmib's message says "No", from his observation (but not measurement) of the G30 and that the 2017 7 Series has the smaller bolt circle.
      11-07-2016, 02:19 PM   #6
njc
58
Drives: G31 520d M Sport
My F11 wheels are ET30. 18 x 8J. Are you sure yours is ET35?
      11-07-2016, 03:43 PM   #7
remmib
remmib's Avatar
Norway
1566
No OEM wheel for the f10/11 is ET35.
The 17x8 and 18x8 are ET30, and the 19x8.5 and 20x8.5 are ET33. Staggered rears are ET44.
N26Ghost496.50
      11-08-2016, 08:36 PM   #8
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
All BMW are transitioning to:
PCD 5x112
CB 66.56
Began with i3/8 and all CLAR based cars (G11/30 and newer). It saves a tremendous amount of weight in the axles and wheels.
No previous gen wheels are compatible for 5/7er.
Almaretto2374.00
      11-09-2016, 11:06 AM   #9
remmib
remmib's Avatar
Norway
1566
PCD 5x112
CB 66.56
Thanks for confirming this.
And I wasn't sure about the CB number as I've seen both 66.5, 66.6 and 66.7.
N26Ghost496.50
      11-09-2016, 11:12 AM   #10
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
PCD 5x112
CB 66.56
CB depends on the manufacturer's tolerances for machining and whether rounding to the nearest 10th is applied. We go 100th of a mm +- 0.02 and no rounding.
      02-02-2017, 12:15 AM   #11
NewM3driver
1110
Drives: 2017 M3 ZCP
pics?
      02-02-2017, 04:02 AM   #12
E90Fleet
South Africa
1311
Drives: BMW
Originally Posted by NewM3driver View Post
pics?
BMW if you are reading, I need a job, Please.
      02-02-2017, 07:06 AM   #13
pharding
308
Drives: 23 Audi Q4 e-tron + 14 X3 28i
No. The bolt diameter is smaller now to save weight. I have BMW F10 winter wheels and tires package and they wont fit the G30.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3
Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del
      08-16-2017, 09:43 PM   #14
g070140
Drives: BMW
PCD 5x112
CB 66.56
is there any difference between 66.5 and 66.6 for the CB? And do you know the offset number?
      08-17-2017, 06:12 PM   #15
morellomax
119
Drives: 2022 M440i xDrive convertible
See post #7
      08-17-2017, 09:00 PM   #16
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
PCD 5x112
CB 66.56
Supplier tolerance requirements and method of rounding to the nearest 1/10mm. I just recently divested my ownership in a Tier 1 wheel supplier a few weeks ago and our engineering was to 66.56 with a +/- 0.02mm tolerance. My recommendation would be to apply a light coating of lithium grease as the CB's that are tight (66.5-66.56) can be a PITA to remove sometimes.
Offset is dependent on the wheel dimensions. For aftermarket, engine, drivetrain, and suspension options can have different clearances on the Gxx cars.
      10-15-2017, 12:58 PM   #17
njc
58
You could try these
http://www.ebay.co.uk/itm/Audi-5x112...38.m2548.l4275
      12-11-2017, 08:17 AM   #18
lpcome
Drives: F10 to G30
The black bolts shown in the picture, M14x1.5 bolts, would they be threading into the wheel hub? Or to the adapter?
Since I believe all 5ers are M14x1.25 bolts?
      12-14-2018, 01:26 AM   #19
gunslinger1976
Drives: awaiting a 435d Gran Coupe
Hi, could I ask if you’ve actually tried this because my local tyre shop tell my the switch to 112 PCD started with the F10 so wheels from the previous 5 series should fit. I was about to buy a used set from eBay!
      12-14-2018, 06:42 AM   #20
remmib
remmib's Avatar
Norway
1566
Wrong, f10 has 5x120.
      01-18-2019, 08:10 AM   #21
gti6cyl
Drives: 2006 BMW 330xi
PCD 5x112
CB 66.56
lemetier, I have a G30 530e 2018.
In your opinion, is it worth buying a set of snows that are 5 x 120 and using adapters to make them fit on my car? Is this a good or bad idea?
Thank you.
Search this Thread:
Advanced Search
5post
