Replacing my valve cover due to PCV; what else?
11-02-2016, 12:26 PM | #1 |
223
Rep 1,073
So, I bit the bullet and ordered my new valve cover because of the squeal noise coming from the main seal. Funny how it goes away when I remove JB4.. hmm.. Anyways, I plan on sticking with JB4 in the mean time while all of the MHD maps are ironed out.
I bought replacement spark plugs while I'm there. Car has 73K, anything else I need to address while I'm there?
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD 2011 BSP 335i-SOLD 2011 BSP 335is- FOR SALE 2018 YMB M3- Current |
11-02-2016, 02:04 PM | #3 | |
223
Rep 1,073
I'd rather not..
2008 MB 335i-SOLD
11-02-2016, 02:54 PM | #4 |
41
Rep 156
I just had to do this. Not sure why it would go away with JB4 though. Maybe coincidence? I did main seal first, squeal came back.
Then I did valve cover. Hasn't come back.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / VRSF Catless DP / Phoenix CP / YCW Coilovers's 6K-18K / M3 Control Arms / Enkei Raijin 18' Wheels / Michellin PSS
11-02-2016, 03:27 PM | #5 | |
2341
Rep 3,539
I assumed it would be the same as N54. I changed mine with updated PCV valve. |
11-02-2016, 03:53 PM | #7 |
41
Rep 156
http://www.e90post.com/forums/showthread.php?t=1197666
http://www.e90post.com/forums/showthread.php?p=18946466
11-02-2016, 04:25 PM | #9 |
41
Rep 156
I did not. Shop replaced main seal thinking it was that, even when I told them it wasn't the root cause. They replaced valve cover for just cost of parts.
11-04-2016, 07:10 PM | #12 |
116
Rep 226
If you have oil in your spark plug wells, it may not be from a leaking VC gasket, but from the spark plug insert to head gasket. To replace those, the injectors need to be removed.
I found mine quite leaky even though my VC gasket was fine. |
orteeze223.00 |
