04-05-2008, 04:07 PM | #1 |
20
Rep 446
EDC Malfunction
My EDC is having some kind of malfunction got a warning through the i-drive and system check. I only have 1000 miles on the car has anyone heard of this problem before?
04-05-2008, 05:15 PM | #2 |
832
Rep 46,029
lol i doubt anyone has it. is it persistent though or does it come and go?
im only asking coz my 335 used to give me suspension-related "malfunction" error messages but they'd go away on their own. im not sure my comment, or anyone else's at this point will add too much value. i would go to M6/M5 forums and search for EDC errors, might be related |
04-09-2008, 12:35 AM | #5 |
55
Rep 2,484
good to see it fixed
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights | |
05-05-2008, 08:02 PM | #7 |
29
Rep 626
Yea I wish that was the case with mine. They reset the computer and road tested it, the fault code came back. The issue is now in BMW's hands, so in 24-48 hours I will have an answer....
06-28-2008, 10:55 AM | #10 |
152
Rep 5,124
07-08-2008, 06:03 PM | #11 |
Rep 90
EDC Fixed
Got my car back Monday. They replaced the EDC controller only to find another error appeared. It was some kind of under voltage problem.
When I initially dropped off the car I mentioned that I had read here in the forums about loose connecters at the top of the shock tower causing EDC faults. While they were waiting on the BMW "experts" in Germany they started poking those connectors and found 4 wires were routed under a metal block, and from what I saw looked like it was screwed down pretty tight. Sure enough several of those wires had there insulation worn through causing the under volt error. They were very lucky that the system found that short before it fried the new EDC controller. The service rep seemed to think that this was an error in the assembly process. Hopefully this was an isolated mistake and not the way all M3s were put together. |
purpleallsectors0.00 |
07-08-2008, 06:17 PM | #12 | ||
48
Rep 1,436
Drives: E70 X5 M
'13 E70 S63B44A
'17 95B GTS |
07-09-2008, 07:07 AM | #13 |
Rep 42
first time I had an edc failure I took the car at the dealership and they told me that the shock's didn't comunicate with one and other, now after 3k km I have edc failure again and I am waiting for 3 weeks for them to fix it... major disapointment
07-09-2008, 01:13 PM | #14 |
531
Rep 5,498
The nice thing about EDC is that the M5/6 have been equipped with similar systems for a while now so problems should not be as mysterious as with say the new DCT tranny....
Nice to see most of these problems are relatively easy quick fixes... Jason
Instagram: jellismotorwerks |
07-09-2008, 08:50 PM | #15 |
12
Rep 73
edc malfunction
got the same problem at 700km , been driving for 800km with problem ,I get an occasional noise on speed bumpsotherwise it handles fine , plugged it in to the GT1 at work and its telling me its a plausibility issue , check connection and they seem to be good , tryed to reset the code but its a hard fault , will take it in monday and get looked at , im not gonna waste my time thats what warrenty is for ,i will report the problem , funny thing is the sport plus setting is constantly on now , but if i set my mdrive to be on normal or sport i can get it to adjust but not with the edc button ???....anyways im just glad it happened a couple days before the H&R springs were to go in and not a couple days after ,,,,, im can imagine now , "sorry sir but because you intalled the H&R we cant look at your edc problem , and now all you warrenty on the shocks are void "
08 M3 Coupe AW FR CF ROOF FULLY LOADED EDC
VORSTEINER FRONT LIP VORSTEINER, VORSTEINER REAR DIFFUSER H&R SPRINGS 20 INCH HRE 890R w EIESRMANN RACE EXHAUST, BLACKED OUT GRILLS , BLACKED OUT SIDE VENT, PAINTED REFLECTORS |
07-15-2008, 12:16 AM | #18 |
12
Rep 73
i also took mine in today waiting for the outcome
07-15-2008, 07:56 AM | #19 |
Rep 42
Got my car back... they said that because of some bumps the shocks stoped comunicating with one and other and now they are just fine... I still don't think they solved anything but anyway I hope it doesn't happen again...
07-15-2008, 09:22 PM | #20 |
12
Rep 73
mine reported that he needed to change the left front shock ! i dont know why , but mine were also making a noise , what a bummer
07-16-2008, 06:59 AM | #21 |
Rep 42
when I had the edc error flashing on the idrive and the car was cold ( I just started it ) I could also hear some noise coming from the shock's but for 2 days now with no error on the noise went away... maybe it's just me because I'm a little scared about this things but anyway...
Skippy9896.00 |
07-26-2008, 06:29 PM | #22 | |
12
Rep 73
i swapped the harness and connector and from left to right and stll the same on the left 2.4-2.5 even when not connected its stuck at those values ??? im pretty sure i read that after 5kph we should see 5v there , not true in my case .
