10-25-2016, 12:04 PM | #1 |
31
Rep 37
Drives: 2016 M235i Coupe
Lost my valve stem caps
So I was in a rush filling up air in my tires before Hurricane Matthew hit Florida a couple weeks back, and in the madness that is a gas station before a hurricane, I left the valve stem caps on the hood and drove off. I want to get a replacement set, but I don't wanna spend all that much. Would the dealership have replacement caps available to just give out, or do I have to order something from amazon/getbmwparts, etc?
BMW CCA Member# {512318}
10-25-2016, 01:17 PM | #2 |
3079
Rep 5,578
Dealer or tire store like JustTires. Firestone etcetera - just go in and ask, even a bike shop.
That would be for plastic or maybe green plastic ones. But I like the metal ones that are thick and have rubber o-rings. |
10-25-2016, 02:26 PM | #3 |
1753
Rep 2,942
I'm a major proponent of brass ones with an O-ring seal. Valves can leak (and have, in my case); the O-ring keeps that under control ... and brass is softer than steel so you're much more likely to strip the cap than the valve if you screw it on wrong.
Look for ones with a relatively short threaded barrel, too. Ones that are too long will not screw down far enough for the O-ring to engage the top of the valve stem.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
10-25-2016, 09:03 PM | #4 |
lieb923
12
Rep 49
Drives: '15 M235Xi
Valve Caps
google milton s451 valve caps. It lets you fill it without removing the cap. It's short 3/4" and plastic so it doesn't affect the balance. Been using them for years. They are very cheap get 2 sets.
10-26-2016, 08:41 AM | #5 | |
4517
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
10-26-2016, 11:05 AM | #6 |
289
Rep 556
Are you always loosing your valve caps in a hurricane? Do you forget to put the valve caps back on during pit stops? Are you just down right forgetful? Well, never buy another valve cap again.
No Loss Valve Caps... Why didn't we think of that! |
Tpeterson156.50 |
10-26-2016, 04:28 PM | #7 | |
1753
Rep 2,942
Use the pricey BMW replacements here as a guide re: dimensions and barrel length. Because I'm (somewhat) anal, I have black ones on my stems since my wheels are powder-coated black. But I buy them in sets of 8 or 12 instead of 4 because, like you, I forget 'em sometimes!
10-27-2016, 12:07 AM | #8 |
3856
Rep 2,876
The cheapo black plastic ones are the minimalist racer way to go - that .05 grams of metal and o-ring would cost you at least .001 per lap. But seriously, put something on now - even if you order fancy ones, the big thing is keeping the valve clean so you don't blow crap into the tire next time you inflate.
Viffermike1753.00 |
Tags |
valve stem cap |
