Pressed metal plates
10-23-2016, 04:21 PM | #1 |
11
Rep 284
Hi I'm in need of new plates for my car as my ones are damaged , I have seen metal ones (pressed plates) anyone know a good supplier?
10-23-2016, 06:25 PM | #2 |
20
Rep 784
Drives: E90 325i m-sport
I got mine from eBay
10-24-2016, 01:39 AM | #3 |
30
Rep 305
Drives: BMW 330i E90
number1plates
10-24-2016, 02:08 AM | #4 |
97
Rep 828
Same - number1plates
10-24-2016, 05:50 AM | #8 |
97
Rep 828
10-24-2016, 06:14 AM | #9 |
11
Rep 284
10-24-2016, 07:23 AM | #10 |
20
Rep 784
I use screws on fronts and plastic frame on rear plate. Tape didn't work for me.
10-24-2016, 07:32 AM | #11 |
68
Rep 937
I've used 3M velcro pads, means you can take them off when you clean the car
http://www.screwfix.com/p/velcro-bra...Fewy0wod6y4P3Q |
10-24-2016, 07:55 AM | #12 | |
30
Rep 305
10-24-2016, 08:17 AM | #13 | |
11
Rep 284
The idea is good, these way i can clean everything behind the plates |
10-24-2016, 08:53 AM | #14 | |
48
Rep 260
I use that really wide stuff but from a local hardware store, one tip I would say is Velcro right to the edge of the plate otherwise the front one tends to bend strait. Also if you put it on wonky really easy to adjust, although be careful with pressed plates as this Velcro is VERY strong and you can bend the plate!! |
10-24-2016, 09:03 AM | #15 | |
11
Rep 284
10-24-2016, 11:15 AM | #17 | |
48
Rep 260
Always keep a spare set of legal plates in the boot just in case now |
10-27-2016, 05:22 AM | #20 | |
48
Rep 260
one thing i will say is if you are using velcro for two sets of plates use a difrent side of the velcro for the front plates and back. that way you wont end up with extra of one kind. So you will have 2x strips with hooks for the rear plates and 1x strip that softer for the car and then 1x strip with hooks for the car at the front and 2x strips that are softer for the front paltes. Make sence? |
10-27-2016, 09:09 AM | #22 |
97
Rep 828
PICTURES!!!!
