Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Best Intake for 2011 BMW 335i N55
      10-19-2016, 05:06 PM   #1
Lrutkowski
Drives: 2011 BMW 335i M-Sport Sedan
I'm looking at purchasing an intake for my 2011 BMW 335I Sedan N55. I just got my car and not really to familiar with BMW's so I might have a few questions. Which do you guys recommend is the best? I'm looking more for the loudest sound. I'm looking at either Injen, BMS, or AFE. Unless there are other intakes I should look at? All options and inputs greatly appreciated. Thanks.
      10-19-2016, 05:09 PM   #2
vivanapoli806
88
Drives: 2012 535i Xdrive Msport
Get whatever is cheapest. Your only going to be getting sound and no significant power gain. If your ok with that just go with bms
      10-19-2016, 05:18 PM   #3
Lrutkowski
I don't really mind spending an extra $100. Honestly from reading and looking it up, I was leaning more towards the Injen intake, but I'm not sure if anyone has any good feedback or if they heard them or tried more then one intake out personally? I'm personally looking for the loudest sounding intake.
      10-19-2016, 05:35 PM   #4
Buchan
Buchan's Avatar
Drives: E92 M3 | F15 X5 | G30 M550i
2011 BMW M3  [0.00]
2010 BMW M3  [0.00]
2011 BMW 335i (Sold)  [0.00]
If you wanted the loudest intake, you could get the BMS Intake and an aftermarket diverter valve. Thats if you want the BOV sound.
Previous- E46 M3 | E63 M6 | E92 N55 335i |E70 X5M |
| E92 M3 | W211 E55 AMG | E30 325is | W204 C63 AMG
Current- '11.5 ZCP E92 M3 | '17 F15 X5 | ‘18 G30 M550i
instagram.com/xuvm
      10-19-2016, 11:49 PM   #5
Lrutkowski
Can you not run a normal bov in the n55?
      10-20-2016, 03:57 AM   #6
Dhillon92
82
Drives: '11 335xi
No, the valve is on the compressor housing of the turbo, not on the charge pipe.
      10-20-2016, 09:31 AM   #7
djohnson92
Drives: 335i
Injen intake is better then bms intake
      10-20-2016, 11:41 AM   #8
philgli
70
Drives: 2011 AW E92 Msport
I have BMS and love it. it is loud and you hear the "blow off" sounds and whistles a lot.
that being said, I would get the Injen for 1 reason only, you can get the piece that goes from the turbo inlet up to the intake also. Having this whole length unrestricted with the same diameter is a plus. that and my stock plastic turbo inlet is leaking
      10-20-2016, 12:09 PM   #9
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Sound wise Injen or BMS
https://x-ph.com/sale/
Phone number 702-494-9435
      10-20-2016, 12:40 PM   #10
johnson47376
johnson47376's Avatar
33
Drives: 2011 335i e92 ///M
Not going to have any noticeable gains with any of them. It's going to be a difference in sound. Ive had Injen and switched to the BMS. BMS cheaper and better sound if you like to listen to the engine. Easier to remove the BMS too which was a big plus for me since I do all my own work. Like I said you're not going to notice the difference between 2-3whp on the butt dyno.
2011 E92 335i ///M Sport in SGM/ 19" Forgestar CF5V/
Pure Stg2 Turbo/ Pure inlet/ GFB DV /Fuel-it Stg2 LPFP/BMS intake/ JB4 ISO BMS BEF/AR Design DP/ ER CP/Wagner FMIC/ Wavetrac LSD/BMW PE/ KW Street Comfort / MusicarNW Level Two Audio Upgrade/CDV delete/3000K HID Fogs/ N20 plugs/ JB4 BT Rev3
      10-20-2016, 10:55 PM   #11
Lrutkowski
I know an intake is not going to give me any noticeable gains and I honestly didn't care about that, just wanted the loudest sound/ spool & it to sound like a bov and from watching videos it seemed like the Injen sounded the best and loudest? Like a $100 does not make a difference to me and I install everything myself so Im not worried about that just the loudest best sounding intake.
      10-21-2016, 12:32 PM   #12
philgli
70
Injen is loudest. adding a charge pipe adds sound too. I just did it and didn't expect any more noise but you do get more air/wooshing sounds
      10-21-2016, 12:54 PM   #13
AtlasM
AtlasM's Avatar
Drives: '11 E92 335xi 6MT
I have the BMS intake along with VRSF charge pipe and intercooler. I put them all on at the same time so I can't say which one adds the most sound, but I have plenty of silly turbo whooshing and whistling noises.
      10-21-2016, 03:31 PM   #14
djohnson92
Drives: 335i
Injen looks better too
      10-24-2016, 09:14 AM   #15
jarmend
Drives: 2012 335i
I ran injen on n55 in SoCal for 6 months and swapped it for BMS intake towards the end of this summer. With Injen on a 95+ degree day I was getting constant IAT too high logged and CEL on really hot days when in stop and go traffic. I also run a Dinan FMIC for reference. Once swapped to BMS no more IAT too high logged on equally hot days to Injen issues with IAT. I would recommend BMS over Injen if you live in a hot climate.
      10-24-2016, 09:49 AM   #16
Dekansnowman
Dekansnowman's Avatar
83
Drives: 2011 335i Sedan Space Grey
Texas checking in and agreeing with above post. Plus, the plastic BMS setup and filter looks sort of OEM.
      10-24-2016, 10:14 AM   #17
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Injen is our most popular seller. BMS is a close 2nd.
      10-24-2016, 10:19 AM   #18
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
808
Drives: 11' Alpine White 335i Sedan
Stock.
      10-24-2016, 01:46 PM   #19
mike@x-ph.com
Originally Posted by 9krpmrx8 View Post
Stock.
Stock sounds better than BMS or Injen? Highly doubt it
      10-24-2016, 03:49 PM   #20
9krpmrx8
9krpmrx8's Avatar
808
Definitely better. Both from a filtering aspect and from a performance aspect since aftermarket intake HP per $ is really low. Ingesting more dirt into your engine isn't a good idea IMO and high flow filters = more debris in your engine.
      10-24-2016, 06:42 PM   #21
surfcali
surfcali's Avatar
Drives: 2016 M3 Mineral White
I have the injen one and it sounds really nice - i've heard it next to a BMS one and the injen one sounds much nicer and is louder.
Performance-wise i've never had both so i'm surprised at @jarmend comment that "Once swapped to BMS no more IAT too high logged on equally hot days to Injen issues with IAT. I would recommend BMS over Injen if you live in a hot climate."
      10-24-2016, 07:00 PM   #22
weehe126
1161
Drives: 2017 340i
Lol this is just retarded. You clearly understand how turbos work.
