2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum My turn w/Drivetrain Malfunction - what to look for first?
      10-18-2016, 11:54 AM   #1
David3
124
Drives: E21 (x2), E46, F15, G05 LCI
2012 550i. Car is new to me and the first turbo BMW engine I have owned. So, after almost full throttle through the gears to the posted speed limit ...let off throttle to cost down to speed of slowing traffic ahead. At about 40mph, I got the dreaded "Drivetrain Malfunction" error along with the engine MIL. Engine idled rough/poorly during the short drive to my driveway (.25 miles). I never got the rpms up to see how the engine ran.
Upon arriving home, I also notice a pronounced ticking noise coming from (seemingly) the left side of the engine (in vicinity of HPFP, I suppose). Code reader indicated misfire in cylinders 1 and 2, low fuel rail pressure, and two proprietary (BMW) codes. I have not had time to upgrade my BMW software and hardware tools to properly read fault codes at this time.
Any ideas what I should focus on? My initial thought was waste gate problem as I surely caused it to open after closing all intake valves (i.e. throttle body) abruptly after turbo was spooled up and working hard. Now, not so sure.
      10-18-2016, 12:38 PM   #2
Quicksilv3r
Quicksilv3r's Avatar
Drives: 2013 BMW 535i M-Sport
You seem like you're on the right track assuming an issue with one of the throttle bodies/throttle actuator(?) due to the fuel shortage indicators. Is the car out of warranty?
-WJV
      10-18-2016, 03:17 PM   #3
David3
124
Yes, car out of warranty at 50k miles.
      10-18-2016, 03:35 PM   #4
SchillerM
90
Drives: 11' 550i, '00 M5, '11 E90 335i
I would upgrade the diag tools and run them.
I ran it on mine when I got malfunction, pointed at Cyl #2 injector. Booked appointment with dealer and got it replaced under aftermarket warranty (which I would highly recommend you look into after this). Cost was almost $2k for one injector, DIY would have been a lot cheaper.
If it is injectors and you DIY, go over to E90 post and look for some N54 injectors. I believe they are same injector, I saw a set of 6 Index 12 injectors for sale over there.
Make sure the car has had the Customer Care done as well, that should put Index 11 injectors in, dealer told me Index 11 and newer don't need "matched" sets anymore, I believe I have 1-12 and 7-11 now.
Goodluck
Matt
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes
Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles
      10-18-2016, 10:40 PM   #5
Sunnyc123abc
30
Drives: 550xi
First Drivetrain Malfunction turned out to be vanos solenoid. Fairly easy to replace. Second Drivetrain Malfunction was spark plugs.
      10-19-2016, 10:59 AM   #6
550Reasons
550Reasons's Avatar
Drives: F10 550i
have you had the CCP done ?
If so then I would say it could be a some sort of sensor, a possibly coil packs going bad.
Check MAF sensors, clean them
2011 550i
2013 M5
2014 M5 CP
2016 550i
      10-19-2016, 05:56 PM   #7
David3
124
Yes, CCP was done by dealer who I purchased the car from. What about fuel pressure sensor or HPFP as possible causes?
      11-01-2016, 10:47 AM   #8
David3
124
Dealer called: Bank 1 HPFP failure, Cylinder 1 coil bad, and a bad spark plug (not sure which cylinder, but suspect #2). $961. I let them do the work even though I already purchased the pump (I can take it back). Dealer said engine CCP warranty did not cover (imagine that!).
      11-02-2016, 09:19 PM   #9
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
Sucks man. N63 is a POS.
      11-03-2016, 08:45 AM   #10
David3
124
5post
