XI 19' wheel
10-11-2016, 01:14 PM | #1 |
Rep 145
XI 19' wheel
So the time has come to order wheels found the ones I want oem style 95s on an 09 e92 335xi. Front wheel is a 9 rear wheel is a 10. Even though staggered rim was considering running a square setup has anyone done this yet. Also for the people running 19s were modifications needed as far as fender rolling?
straight pipe mhd led interior dci syle 95s m3 high spoiler
10-11-2016, 02:02 PM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
if offsets aren't super aggressive i'd just run 255/30/19 or 245/35/19 on all 4 if you want square
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
10-11-2016, 03:04 PM | #5 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
The stretch will also change the diameter of the tire, so even though they are the same size before mounting, they won't be afterwards. I don't know how drastic the difference is though.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
10-13-2016, 10:57 AM | #6 |
285
Rep 615
Drives: '11 E92 335xi 6MT
My 19" setup on my '11 LCI E92:
Front 19x8.5" +32 235/35-19 -2.25 camber Rear 19x9.5" +32 275/30-19 -2 camber I'm lowered on B&G S2 springs. This is the ride height: With this setup I get a little bit of rub from the front passenger wheel on the inner fender liner when I crank the wheel to mostly full lock in a parking lot--there's a bit less clearance on that side because of the oil cooler. In the rear it mostly clears except on big bumps I get occasional rub, mostly on the driver side since I'm on that side and weighing the car down more. I'm going to roll my rear fenders at some point. Note that the front E92 fenders are plastic and can't be rolled. |
10-13-2016, 09:26 PM | #7 |
Rep 145
Ill be on 19×9 in fron and 19×10 in rear i have 2553519 all the way around on stock ride height...
10-16-2016, 03:13 PM | #9 |
60
Rep 341
I use style 95 as a winter wheels set up on my 2011 e90 xdrive, have to say it all depends if you are on stock suspension. On my xdrive suspension I did not rub at all with 235/35/19 and 265/30/19 but when I got the coilovers installed I had to do a fender roll at the rear.
10-17-2016, 02:19 PM | #10 |
Rep 145
haha
Lol these are the wheels im gonna run for summer. I felt they were cool enough to run in the summer. Now im rethinking that...^^^^^
10-27-2016, 06:57 PM | #11 |
202
Rep 749
Drives: 335i xDrive
+1 I did
Avant Garde: M359 19" 235/35/19 ET: 35 265/30/19 ET: 38 Stock Suspension: Eibach Springs: |
10-30-2016, 07:51 PM | #12 |
60
Rep 341
Yeah i run with the style 95 as winter wheels because I use Stance sc5 during the warmer months...lol...
