10-04-2016, 03:34 PM | #1 |
1165
Rep 1,931
Harness Bar and seats
Anyone install a harness bar yet?
It looks to be a 49 or 50", but was wondering if anyone installed one and knows exactly. Cant get an exact measurement because of the way the seatbelt clip is molded. I wonder how much of a challenge this is going to cause. Also, anyone know what the max size for racing seats are to fit? Thanks!
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-03-2016, 03:39 PM | #2 |
715
Rep 1,541
Almost every stand alone harness bar I've seen for various cars is just for looks. I would be very careful using one unless it's absolutely designed for function and not form.
The only "harness bars" that are legit will be ones integrated into a 4 point cage or something that is so close to what a 4 point cage is that you might as well get an actual 4 point cage. Edit: I've used these before: https://www.schrothracing.com/products/tuning Here is a Sparco bar...
11-04-2016, 11:04 AM | #3 | |
125
Rep 356
11-04-2016, 03:05 PM | #4 | |
463
Rep 957
I use quick fit, yes not manufacturing approved, basically it's stitching, stitching is designed to fail if seat folds, so you don't get decapitated. While a harness and race seat would be safer on track, not so much on street, unless your rocking a helmet full time. If I am on the track and the roof is collapsing, given the strength of the roof in rollover testing I'm probably leaving in a helicopter or a van. I.e. More risk for me on the street. |
11-07-2016, 09:59 AM | #5 | |
715
Rep 1,541
I might go with a 4 point and harnesses in the future.
11-07-2016, 11:57 AM | #6 | |
3805
Rep 2,860
And wouldn't they be better if routed outside the supports for the headrest, so as to keep neck clearance? |
11-07-2016, 06:52 PM | #7 |
1165
Rep 1,931
I've decided to just keep car as is and purchase a Spec e30 for 7-8k already race prepped.
See you in Nasa!
www.nybmwcca.org
11-22-2016, 07:53 PM | #9 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I have been working with them to develop a version for the F30 (which should fit in the F80 too), and I imagine they'd be interested in designing one for the 2 series as well, since it would serve double duty with the M2. They're also working on race seat mount adapters that use the factory floor mounts...the mounts should be fairly accommodating to various seats, but the specific seat they're using for the design is the Recaro Profi XL (which just happens to be the seat I'm interested in).
Ahead of the curve for specF30
11-23-2016, 03:30 PM | #10 |
1165
Rep 1,931
Have you made sure the seats fit in the 235?
We dont have alot of room to work with. I emailed those folks a year ago about a harness bar for 2 series, no answer. IND has a bolt in full cage available for around 6k.
www.nybmwcca.org
11-23-2016, 06:01 PM | #11 | |
558
Rep 1,477
Drives: 335i
I have never tried emailing them; the company has various industrial manufacturing operations, so it might be better to just call and ask for Ian, who is their dedicated auto engineer...(and he's a die hard BMW guy). By the way, Ian also worked up a set of anodized aluminum spacers to make the M car tension struts fit our cars. Some guys are having these custom made to get the specs just right (or buying off the shelf spacers that are close, then doing a little fitting to make them work), so I suggested that B-K consider offering them as a drop in kit in their parts catalog...Not sure if they plan to do so, but they may do if people show interest. I'm sure the IND cage is nice - but 6k is steep, and I imagine it's a pain in the neck to get in and out.
11-28-2016, 11:32 PM | #12 |
910
Rep 3,452
Drives: Harrop E90 M3
I'm in the same boat as a few others here. Need a nice bar or cage asap. I'm getting ready to remove the M Performance seats and quick fit 4 points and install some Profi SPG XL seats with 6 points. Local tracks will no longer allow the 4 points after the first of the year, even the Schroth Profi ASM and will require a HANS even on open lapping if you're using harnesses. I would've thought there'd be an option for something other than the cage from IND by now. May have to build my own if nothing comes out soon!
11-29-2016, 12:54 PM | #13 |
1165
Rep 1,931
IND has a full cage under the m2.
It should bolt right since its basically the same car. Heavy price tag tho.
www.nybmwcca.org
