F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Remap on F30 320d Efficient Dynamic
Extreme Powerhouse
      10-04-2016, 01:59 PM   #1
Imran1988
Drives: BMW 320D
Hi,
Has anyone done a remap on a F30 320d Efficient Dynamic edition? As was doing some research and stumbled on this website:
Celtic Tuning - they say this:
The BMW 3 Series (F3x) 2012> takes the power from 163bhp up to 238bhp and the torque from 280lb/ft up to 326lb/ft. This stage of software is designed as a software upgrade only meaning it is all within safe tolerances of the engine and drivetrain and requires no hardware modifications. With our diesel upgrades you can expect to see upwards of 10% fuel saving dependent on driving style.
And quoting £360
Worth it or Not?
Thanks
      10-06-2016, 07:32 PM   #2
Imran1988
Drives: BMW 320D
Anyone?
      10-06-2016, 10:40 PM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Not a lot of people here in the States doing remaps (all our cars have DEF/SCR systems and it's a bit more complicated.)
Racelogic and Ecotune are notable tuners that I've seen, and a few reviews.
      11-11-2016, 02:36 AM   #4
TC-performance
Drives: E60 535D @ 446HP
We made a lot of 320D ED. It's a same as normal 320d 184HP.
Sample:
      12-04-2016, 10:33 AM   #5
emanuel1
Noob
Germany
Drives: E46 320i
for UK there's a guy called simon whom remaps bmws. I've looked him up and had a chat with him, as I was also under the impression that the 163 and 184 versions of the N47 in the 320D are the same engine, just less fuel injection in the upper range of RPM (same torque). he confirmed the same as did TC-performance, that the engines are identical.
So technically you could take both engines to 210bhp and around 450Nm. Just double check that the cooling is identical if you plan to put it on the racetrack and that the gearbox/clutch can handle that torque (gearboxes are different).
      04-02-2018, 04:04 PM   #6
plikmuny
plikmuny's Avatar
Germany
8
Drives: BMW 320d, 330D(2019)
Are you from Germany? Do you know anyone similar to Simon? I asked him but he says his service limited to UK. I live in Bayern. If you know any notable remapper nearby my place pls suggest. If you know more details also including costs and the experience from customers if you know of about their experiences pls. Thanks in advance. I am also planning to ecu remap my f30 320d ED remapped....
f30post
