10-03-2016, 08:04 PM | #1 |
1381
Rep 3,834
M2 Track Setup?
Hello, looking for wheels size and offset ideas. Please post your track wheels setup with offset here. Thanks.
Daily: G12 750 MSPORT Weekend Car: E90 M3
10-04-2016, 09:30 PM | #2 |
1418
Rep 2,560
Drives: Rapidly from A to B
Still running stock at the track but am also interested in what others are running. Thinking about a square et 35 19x9.5 with a 5 mm spacer in front. I did a test fitment with 265/30s and this will work.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
JNoSol1381.00 |
11-14-2016, 10:13 PM | #4 |
125
Rep 8,745
What is the front wheel offset?
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
11-15-2016, 07:23 AM | #5 |
915
Rep 3,456
Drives: Harrop E90 M3
11-15-2016, 09:48 PM | #6 |
125
Rep 8,745
Thanks, but now I am a little puzzled with the spacer size. You really meant 15mm, not 5mm?
Sorry for all the questions.
11-16-2016, 09:04 AM | #7 |
BimmerPost Supporting Vendor
813
Rep 526
11-16-2016, 04:31 PM | #8 | |
125
Rep 8,745
I am a little averse to tracking with larger spacers, as I had a mishap once, (which could have been a fluke) So trying to limit my spacers to 5mm. Thanks
11-16-2016, 10:06 PM | #9 |
915
Rep 3,456
No I meant 15mm. The car has Clubsports installed and needs the inner clearance. The wheels sit perfectly flush at -1.5 camber up front. The spacers are not ideal, but it's what's necessary on this car to keep a square setup and the ability to rotate the tires. Custom wheels can fix that, but the ability to rotate is nice. I just make sure to check the torque on the wheel studs when the wheels are off and the lug nuts before each session.
M3 Adjuster7905.50 |
11-17-2016, 06:47 AM | #10 | |
125
Rep 8,745
11-19-2016, 11:33 PM | #11 |
2051
Rep 3,714
Does the tire stick out past the fender with this setup? I bolted a 18x10 ET25 with 285/30/18 Hoosier to my M2 and it stuck out a lot.
11-21-2016, 07:34 AM | #12 |
813
Rep 526
11-21-2016, 08:38 AM | #13 | |
2051
Rep 3,714
The rear has more clearance issues than the front on the M2, correct? |
11-21-2016, 08:56 AM | #14 | |
813
Rep 526
We chose to run an et35 (which limits us to a 275 in the rear) so that we could cut all 4 wheels with the same offset and simply run a spacer up front to make it work which would allow us to rotate front and rear wheels without any issues. If you cut a staggered set you could get away with a 275/295 stagger with an 10.5-11" rear wheel. |
11-24-2016, 05:07 PM | #15 | |
2051
Rep 3,714
How big of a spacer do you use on the front with the +35 wheel? I may be wrong but it did not seem like I had a lot of strut clearance at full lock with a 18x10 +25 EC7. The tire was a 285. I'm on stock alignment |
11-28-2016, 07:21 AM | #16 | |
813
Rep 526
I haven't measured the inside clearance on the rear exactly but if I ran a 10.5 or 11 the offset would have to be higher, closer to +47 or so with the 11" wheel. |
Tags |
bmw m2 track wheel, bmw m2 wheel, offset track, signature wheel |
