Is my waterpump going out?
10-03-2016, 04:16 PM | #1 |
51
Rep 273
My e93 has about 48k mi, and last week after letting it run idle, and checking inpa for rdc faults (getting tpms errors), the car starting making a very loud roaring or fan noise, as if it was going to explode.
Is there a way I can visually check, or do a diagnostic in inpa to see if the waterpump is going out or something else, or do I have to just drive it until the check engine or car fails? I would like to bring it to the dealer, but A.) its about a hour away, and B.) It sucks cause if it works up to that point, its a $140 diagnostic fee. Or in other words from a BMW rep regarding the hpfp recall "if the part hasn't failed, they won't replace it". Last edited by BMWMusician; 10-04-2016 at 09:12 AM.. |
10-03-2016, 07:42 PM | #2 |
187
Rep 589
The water pump usually throws a DME code before it fails completely. 2E84 or similar, I think?
Is your AC on? The fan can get really loud if the AC is on and it's hot enough outside. |
10-04-2016, 09:20 AM | #5 |
242
Rep 1,354
I ran into the same thing.
My car produced the roaring noise at idle while loading up music to the CIC. No codes were thrown. A few days later the water pump went out while driving. Take the roaring noise as a warning to get the pump and thermostat changed NOW! |
10-04-2016, 12:29 PM | #6 |
51
Rep 273
Same thing about this "no dipstick" oil sensor. I just happened to ask the dealer to do a inspection and they found out the oil sensor was faulty.
Kind of on the fence what I should do? If I take to the dealer, lets say the waterpump is working, but not yet "failed". They will charge me a $110-150 diagnostic charge. Then lets say 5 mi leaving the dealer, the car stalls, I have to get it towed, and there's a $200 deduct. for warranty, so I'll be out of $350. Or do I keep driving the car until the temperature light comes on or stalls, then take to the dealer. Last edited by BMWMusician; 10-04-2016 at 01:26 PM.. |
10-04-2016, 03:09 PM | #7 |
164
Rep 598
The pumps are electric and generally either work or they don't - once it dies, it's dead. And you'll need a tow.
If you have fault codes for a failing pump and you've had symptoms, maybe they will consider it bad and change it. Well, it's really up to the warranty company, the dealer will change anything you ask for. The dealer just needs to confirm to the warranty company that it's faulty. The dealer sees bad pumps all day long. I would first look for codes, and if there are codes, then call the dealer and tell them your fan is running like crazy and you have water pump fault codes, and ask if they can go ahead and change it under your warranty. Oh, and change the thermostat (even out of pocket, about a hundred dollars) at the same time. They shouldn't charge any extra labor. If they try to, raise a stink, because it's actually no extra labor. |
10-04-2016, 03:47 PM | #8 | |
51
Rep 273
How about I post some inpa readings today? See what codes are showing and do I need to run any temperature diagnostic test to see why the car sounds like it's overheating? I will check my coolant as well and post pics. |
10-04-2016, 04:53 PM | #9 |
164
Rep 598
When the pump fails, most people suggest that it's the electronics in the control board that cause the failure. The pump is driven by an electric motor controlled by the on board electronics.
You need to scan for codes. The dealer won't file it under warranty without codes, especially if the pump is working when you get there. It all comes down to how the dealer wants to do its diagnostic. If you see pump fault codes, call the dealer and ask them if they can go ahead and change the pump under warranty. Note that if you do have fault codes, keep in mind that it could fail and leave you stranded at any moment. When it fails, you will get a temperature warning and a few seconds later the car will shut the engine off. It's also possible nothing is wrong. If you let the car idle for awhile it will kick the fan on full blast to cool it down. That is normal. |
10-04-2016, 05:30 PM | #10 | |
51
Rep 273
As for scan tools and faults, I have inpa with a one stop electronics k+dcan cable. Is that good to use, or do you suggest another scan tool, or carly for bmw, etc? |
10-05-2016, 11:24 PM | #11 |
164
Rep 598
I use Carly. It's easy to use, and I don't have to fool with figuring out installing and using other software.
But it's just one way to get the job done. I just have no idea about inpa or how to use it. But if you have it working, use that. |
10-06-2016, 07:01 PM | #12 | |
1904
Rep 6,968
Drives: 2007 Black/Black 335i e90
Other then that, there is no real way to test for the health of the thermostat and water pump. When it goes, it just goes. You'll know.... Car will go into limp mode and you'll get a red over heat warning on your dash. At 48k, you still have 27k before you have to think about looking for a sale on parts. Lots of DIYs on this one |
10-07-2016, 01:38 AM | #13 | |
242
Rep 1,354
My car at 46K would produce the roaring sound after 30-40 minutes at idle. Even after reading that this was a waterpump issue I did not want to believe it. Within a week or two of it first producing the roaring noise my pump went out. No codes were thrown UNTIL the pump finally went out. As with others, my pump did not go out with a circuit board problem, but a crack in the internal components. After replacement I can let the car idle for over an hour at high outside temps, and then the fan MAY kick in with a fairly low volume sound. |
10-09-2016, 10:07 AM | #14 |
51
Rep 273
That's the issue. The car actually has to show clear indication the water pump is going out. If not, the dealer will charge a $130 diagnostics fee, and lets say it goes out 40 mins from leaving the dealer after the diagnostic, then tow it back, and $200 ext. warranty charge + $100 for thermostat.
So literally idk if I have to drive it until it breaks, which sucks. |
10-13-2016, 03:56 PM | #18 |
14
Rep 389
Been there before. Just got back into an older model 335. First week I went ahead and had the pump, thermo, and plugs changed. Should be good to go. Its a lifetime pump and warranty installer.
10-14-2016, 12:38 PM | #19 |
51
Rep 273
10-24-2016, 07:25 PM | #21 |
Rep 2
my car overheated yellow then red in seconds. bot the pump & t-stat 08- 335i 102k miles.
Ran the Wp Purge program- you can hear the WP moans back and forth, but it never speeds up (engages) and no a/f flows into the expansion tank. |
