10-03-2016, 03:07 PM | #1 |
55
Rep 356
18" wheels were rubbing on the caliper...
Hey Guys,
I was trying on 18" Apex wheels on the M2 in the driveway, and the caliper was rubbing. I see some guys are mentioning 18" setups - has anyone pulled this off without rubbing? I'm unsure how someone can be running an 18" setup, if I can't even let the wheel spin freely without scarring the caliper.... Help! |
10-03-2016, 03:32 PM | #2 |
538
Rep 624
10-03-2016, 03:43 PM | #3 |
BimmerPost Supporting Vendor
813
Rep 526
Your offset is probably wrong. We have fit multiple sets of 18" wheels on our M2 including a set of APEX's.
M3 Adjuster7904.50 Taskmaster2465.00 |
10-03-2016, 08:16 PM | #4 |
287
Rep 312
OP,
What wheels size and offset are you using? For the EC-7 wheel, Apex recommends 18x9 wheel with ET31. See the group buy thread. I'm hoping that is not what you were trying on as I'm about to pull a trigger on this square setup. That would be one unpleasant surprise.... |
10-06-2016, 09:51 AM | #6 | |
357
Rep 292
10-06-2016, 09:54 AM | #7 | ||
62
Rep 86
2017 BMW M2 | BSM DCT Exec
BMW CCA Member ID: 522493 |
10-06-2016, 12:03 PM | #8 |
1423
Rep 2,657
OP did not mention which APEX 18" design he/she tested, so I am thinking they tried an ARC-8 or PS-7 design which does not in fact clear (unless using 19" diameter). The 18" EC-7 design has superior caliper clearance, and is one of the few 18" wheels on the market that will clear the steel M2, M3/M4 brakes
- Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 10-06-2016 at 01:51 PM.. |
10-06-2016, 01:12 PM | #10 |
62
Rep 86
245/40-18
10-06-2016, 02:00 PM | #12 |
62
Rep 86
I'm a total noob when it comes to this stuff, but from what I've learned through talking with those that know what they're doing and browsing the forums, it's not too small. We want narrower tire width for winter conditions. The narrower the tire, the better the traction will be in deep snow. With the car being rear wheel drive, I would want a narrower tire on the rear so the 245 would be an advantage over the 255 width.
MilehighM3914.00 |
10-06-2016, 02:59 PM | #14 |
Moderator
121
Rep 281
We now have some 18x9.5 track wheels available for the M2.
http://f87.bimmerpost.com/forums/sho...0#post20667960 Last edited by Rudy@tirerack; 10-06-2016 at 03:11 PM.. |
BAN_M2C4178.00 |
10-06-2016, 04:02 PM | #15 |
62
Rep 86
Is the Tire Rack website showing incorrect wheels then? If you try to configure an 18" winter tire and wheel package for the 2017 M2, the 18" BBS SR comes up as a possible option.
10-06-2016, 04:11 PM | #16 | |
Moderator
121
Rep 281
The BBS SR will work in a 18x8 ET32! |
10-07-2016, 03:59 PM | #17 |
55
Rep 356
Hey Guys,
The wheels we tried on were ARC-8....as Apex replied earlier, they don't fit!!! So now I'm scared..how do we know what fits, and what doesn't, on the market? PS - I know this has been addressed a million times, what's the thickest profile someone has used on front/rear with 18s', 2XX/40?/18 ? |
10-07-2016, 07:07 PM | #19 | |
1423
Rep 2,657
We do not have extensive experience with the M2 platform just yet, but I would like to further explore the limits of this chassis once we are able to perform more R&D. We will update the community as we learn more - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
BAN_M2C4178.00 |
10-07-2016, 09:19 PM | #20 | |
Wheelsucker
199
Rep 1,280
10-08-2016, 02:57 PM | #21 | |
1423
Rep 2,657
APEX 18x9.5" ET22 Up front, our 18x9.5" ET22 will have just about the same inner strut clearance (1mm more), and the outside edge of the wheel will EXTEND an extra 13mm towards the front fenders. In the rear, our 18x9.5" ET22 will have 24mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 12mm towards the rear fenders. For a street car looking for a flush fitment with street tires, this is probably a good way to go with 265/35-18 street tires. The lower offset would lend itself to a flush fitment without the need for spacers, Depending on ride height and tire brand, a small amount of neg camber may be necessary. For a track car running r-compounds, it may be better to run our 18x9.5" ET35 wheel for more clearance to the fenders front and rear, allowing more space for r-compounds that tend to run wider then the avg. street tire. This would also allow more room should the driver want to bump up to 275's. APEX 18x9.5" ET35 Up front, our 18x9.5" ET35 will have 12mm LESS clearance on the strut side, and the outside edge of the wheel will be at the same point. In the rear, our 18x9.5" ET35 will have 11mm MORE clearance on the strut side, and the outside edge of the wheel will RETRACT 1mm. With 12mm less clearance to the front struts, this fitment would likely need small spacers up front for proper strut clearance. APEX 18x10" ET33 - Square Up front, our 18x10" ET33 will have 17mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 9mm towards the front fenders In the rear, our 18x10" ET33 will have 7mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 7mm towards the rear fenders With 17mm less clearance to the front struts, this fitment would definitely need small spacers up front for proper strut clearance. Negative camber would also be a must for the front of the car. - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 10-10-2016 at 02:41 PM.. |
MilehighM3914.00 |
10-09-2016, 11:55 AM | #22 | |
BD_e92
358
Rep 1,748
